brandonozz
Oil Capacity Seems Off?
brandonozz
I just changed the oil on my C165 for the first time.  I added a little less than what the manual for the K341 calls for and stopped to let the oil settle and check the oil with the dipstick.  The oil is showing at least a 1/4" over the full mark???
Before draining I warmed the engine well and let the oil drain overnight.  The dipstick tube seems to be correct.  From what I've found the capacity is supposed to be 1.9 quarts and I only added about 1.6 to 1.7 quarts yet it is showing overfilled.  Did Kohler ever make a shallow pan for these engines that would require less oil capacity?
Thanks for your advice, Brandon
rmaynard
My method is add a quart, then top off until the oil level is correct on the stick.
However, I think the amount should be 1.5 qts.
gwest_ca
Lube and capacity chart
Garry
brandonozz
Well Bob, based on the manual Garry provided it looks like your correct - 1.5 quarts.  I looked in themanuals but didn't see that chart and searched here for the (aparently incorrect) information at Kohler.
http://www.kohlerengines.com/onlinecatalog/pdf/tp_1346_c_all.pdf  There must have been different pans on some at least,
Thanks guys, I guess I get to get a little sloppy draining 1/4 quart as my drain pipe is straight down between the frame rails.
Bob I agree about adding less than you think it needs and then topping off as necessary ...... I thought I was!     :banghead:
Kelly
Big pan blocks use more oil than small pans blocks, the 165 has the small pan.
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • davidfindlay
      By davidfindlay
      Looking to find a new home for my 84 (I think) C-145. It has a dump trailer with the enclosure for leaves, the PTO impeller to get the leafs into the trailer, the hoses for deck-to-impeller, impeller-to-trailer.
      I haven’t run it in over a year.
      The battery and the cable to the battery probably need to be replaced.
      Comes with a new head gasket still in the bag.
      Seat is cracked but still comfortable.
      Happy to answer questions or take other pictures.
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
