benjiboo
Part # For C-160 Headlight Lense?
benjiboo
Can anyone tell me what the part number is for the headlight lense for my C-160? The only things my tractor is missing is that headlight lense and the contacts that go inside the headlight bulb housing where the bulbs drop in. The actual housings for the bulbs are there, but just the wired contacts with the springs are missing, any ideas on replacement contacts for them? Thanks everyone.
Edited by benjiboo
AMC RULES
The lenses themselves are usually on ebay...
search "wheelhorse lens" and see what happens.
The light buckets show up there too...
might have to keep checking back though.           :handgestures-thumbsup:
Don't forget our :wh: parts vendors found in the vendors section here on the forum too.
rmaynard
Don't forget about part search engines such as:
http://www.propartsdirect.net/p/Toro-Lawnmower-Parts?aribrand=TO or
http://www.smallenginepartswarehouse.com/p/toro-parts?aribrand=TO
You can find all available part numbers there.
gwest_ca
http://www.partstree.com/parts/
103771 replaced by 98-1713
ASM - LENS W/DECAL
Single wire light socket pigtails can be had from automotive jobbers like Napa.
Garry
MalMac
Yep the socket pigtails can be bought at NAPA. I Just got a box of them this past summer.
benjiboo
Excellent! I knew you guys could come through. Thanks guys!
608KEB
Do you think the headlight lens are originals or reproductions with a vinyl sticker on the back side of the Lens?
546cowboy
I have two brand new ones that I got before I sold all my tractors. As I recall they were about $36 each from my dealer.
KC9KAS
Same here...not very expensive either.
benjiboo
So does anyone have a part # for the socket pigtails from NAPA? I've searched their website over and over and can't find anything even close.
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
