.JPG.9f2ecb26065c66527b0730084ab7fc7a.thumb.jpg.7dc8a04d9a53d44ee2b23f26ee94496f.jpg)
		November Tractor of the Month- Custom Workers !!
					By
stevebo-(Moderator),   in Wheel Horse of the Month
				November Wheel Horse of the Month
				 66 members have voted
						1. Pick tractor-
									Stevebo's 520HC4
									Squonk's weight hood6
									953 Nut's Hot Rod 9535
									Hodge71's 18 Auto5
									Don1977's C120/1805
									C-101plowerpower's C1013
									Diesel Cowboy's C1606
									Wheeledhorseman's Tiny Tim3
									Sorekiwi's Ranger4
									Stigians GT-14+23
									Smoreaus 417A6
									Octfst's 8674
									Walfish's cruiser12
Similar Content-
			 By tractorboy79 By tractorboy79
 I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
 Images below of cylinders to show similaritys.
			 By BuffaloD200 By BuffaloD200
 '74 D-180
 My friction disc in gone on my clutch. I saw the old post about making a new friction disc, so I'm not concerned about that.
 I managed to remove the front clutch plate and double v-belt pulley. But I can't separate the two. When I took the assembly off the spiraloc washer popped off on its own. I HAVE READ THE MANUALS.
 So I should be able to just remove the pulley from the front clutch and continue with step 4. The v-belt pulley is loose as all hell and flops around like a dead fish. It seems to be hung up on a ring or bearing race.
 So my thoughts are grab a BFH or sparky the blue tip wrench.
 Is there an unpublished step 3.5, or some trick?
 Hey all,
 My '74 D180 has a lot of trouble pushing snow. Weighted tires, but nothing else at this time. I've found it gets stuck frequently and only one wheel spins. Do these tractors not have a limited slip/locker arrangement? How does everyone manage with the infamous one wheel peel?
 Hey all, I need to install a drive belt on my 75 D180 for my snowblower. I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure. The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell. Do I have to remove the PTO pulley? That seems to be a required service item.
 Same question for my 80 D200 as well really.
 Using the recommended 4L490W belt.
 Thanks
			 By ihatephones By ihatephones
 I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
 Where can I get one that's not on eBay for $200?
 I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
