zanepetty
That's what I did, charlie. I sprayed my sealer then top coated over that. Its flash time was 20 mins. Which I hate.
zanepetty
Got all the steering components, pulleys and trans painted today. They look surprisingly nice!! No runs. The sag on the frame dried up to where you can barely notice it.
post-11334-0-70323300-1387315141_thumb.j
post-11334-0-02715600-1387315244_thumb.j
stevasaurus
Looks pretty nice Zane...you getting ready to do the hood and seat pan???  :)
zanepetty
I'm going to do the engine and starter tomorrow then the day after that I'm doing sheet metal!
kudzu3
Good job Zane! I'm sure looking forward to seeing the finished product, but... "you can't rush perfection".  :bow-blue:
zanepetty
Finally repainted my hood AGAIN!! it turned out extra nice. I'm surprised :) now all I got left to do is my tool box that I just got in the mail, break caliper, wheels and seat pan. Then for reassembly..I'm getting scared..
post-11334-0-50009600-1388189018_thumb.j
post-11334-0-65402500-1388189128_thumb.j
post-11334-0-22798700-1388189224_thumb.j
kudzu3
Just sat down to relax after a busy day, turned on the computer and saw this. Wow! :bow-blue:  What a great paint job! This put a smile on my face :) .
zanepetty
Thanks tommy. Glad to hear that :) I am extremely pleased. The pics inside make it look a little bit orange but its really not. I'm glad its over. Painting the hood is too stressful!
C-101plowerpower
damn, that paint sure looks great :text-+1:  great job, hope to get my paint that sharp
Koen
zanepetty
Thanks a bunch, koen.
stevasaurus
That really looks great Zane...WOW.  :)
zanepetty
Thanks friend!
51Chevy
Looks great I'm looking forward to seeing it finished
zanepetty
Thanks. Does anyone know where I can get a gasket that goes between the carb and back of the air filter housing?
kudzu3
I believe you can get gasket material from any auto parts store and make it yourself. If you can't find any, let me know and I'll send you a piece.
zanepetty
I don't know how to get the hole just right.
zanepetty
The decals vinylguy (terry) made me look absolutely amazing. Here's a few.
post-11334-0-45796700-1388677921_thumb.j
post-11334-0-19851400-1388677985_thumb.j
post-11334-0-42183700-1388678025_thumb.j
rmaynard
Looking great Zane. :thumbs:
zanepetty
Thanks , Bob. Work with my tractor has been slow the past week. I'm itching to put this project to rest so I can have my tractor again.
kudzu3
That's nice, I didn't know you could get that stuff.
zanepetty
Yes. Pictures don't do it justice. Go to redoyourhorse.com. its easy. I think you'll be very happy with the results. And if you're a supporter you get 25% off. Thats worth it.
redrooster
Zane what type of paint are you using it looks good. I want to use a good quality paint. Is it true that you have to paint over primer very soon after it is applied?
zanepetty
I'm using classic series viper red. I believe ae10 is the paint code. That is true. You want to do a wet on wet application. If not you'll have to sand your primer which takes a while and if you sand through in spots, your top coat won't have an even color.
redrooster
Does this mean I can not take several weeks sand blasting parts spraying them with primer and than painting them.
Also where did you purchase the paint you used?
zanepetty
Well its up to you. If you did that you'd need to scuff up the primer before you paint the part. Or if you sanded through you'd want to recoat with primer or sealer then let it tack then spray the color. Also if you prime the pieces and then scuff them up and do go through down to metal it will rust quick. Just be careful :) I got my paint though a family friend who has a body shop so I don't know where it came from. But Napa has paint called crossfire and its good. Some o' rielys sell automotive finishes. You could check there.
  • Similar Content
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • giant_g2
      By giant_g2
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here https://greystone-3d.square.site/product/customizable-wheelhorse-hood-ornaments/10
