zanepetty
Hey everyone. As you know I'm hot and heavy into wheel horses now and many of you have answered many of my questions and helped me TREMENDOUSLY. But I've finally decided to give my horse a paint job and I thought I'd post pictures along the way. Here's the engine cleaned,sanded, prepped and primed. This is the first thing I've done. :)
post-11334-0-03849300-1382771219_thumb.j
post-11334-0-67915800-1382771247_thumb.j
post-11334-0-69543800-1382771271_thumb.j
post-11334-0-20746100-1382771306_thumb.j
post-11334-0-49625200-1382771343_thumb.j
post-11334-0-58681000-1382771384_thumb.j
Edited by zanepetty
AMC RULES
Now how'd you get that engine so clean?
Coadster32
Get-r-done!!!   Motor looks blasted to me.
zanepetty
I spent some time with a spray bottle of mineral spirits, a flat- head screw driver and a wire brush drill attachment! It took some work but it cleaned up nicely. I'm going to keep the pictures coming so you can see what I'm doing and put in constructive criticism if need be! :)
kudzu3
Nice job! I'm in the beginning stages of a restoration also (my first) on a b 80. My engine required a re build. I cleaned it much as you did, with diesel fuel, wire brush and sand paper and decided, for some reason, to go with black on the engine, used rustoleum engine paint and it turned out really nice. I wish I could figure out how to post pictures, I'd love to share my rebuild with all the nice folks here and as you say, constructive criticism is welcome. Looking forward to following your restoration, thanks for sharing.
zanepetty
No problem , kudzu. Thanks for looking! I was in the same boat as you with the picture deal until a few nights ago as I'm still kind of new around here myself. I just went to the red square store and became a supporter. Well worth it to me. If you're not a supporter the picture size has to be so small.
zanepetty
My new toy and what I've been working on today ! I got it at harbor freight for a good deal. It works great!
post-11334-0-17964600-1383072203_thumb.j
post-11334-0-71939200-1383072222_thumb.j
post-11334-0-26769900-1383072244_thumb.j
zanepetty
Here's the finished product. All pieces are completely bare metal inside and out.
post-11334-0-39915300-1383084620_thumb.j
Edited by zanepetty
AMC RULES
Parts look great...using sand as your media to strip the paint?
Patrick Reese
That's one spiffy looking engine!
zanepetty
A few more before primer.
Yes I'm using play sand haha. Its much cheaper than black diamond and it works great!
post-11334-0-33558100-1383090146_thumb.j
post-11334-0-23140600-1383090170_thumb.j
post-11334-0-04030700-1383090258_thumb.j
post-11334-0-37348800-1383090302_thumb.j
zanepetty
Slick as a baby's bottom :) sheet metal pics soon to come!
post-11334-0-44711100-1383341141_thumb.j
bitten
You have to watch using play sand. It will warp your sheet metal.
stevasaurus
Great pictures Zane...keep them coming.  :)
zanepetty
Thanks pal! I'll have some sheet metal pictures tomorrow.
squonk
Play sand also has moisture in it that can remain on the stripped metal as well as clog the blaster.
zanepetty
I'll wipe it down with mineral spirits really well before I paint. I hand pick my bags from places that store it inside only. If its the least bit moist I don't use it. I hope that works
Edited by zanepetty
rmaynard
I hope you are using a good respirator when you blast with sand.
zanepetty
Yes I am :)
zanepetty
I know its been a while since I posted pictures but I've been hard at work on my tractor. I initially wasn't planning to go to such pains but I've ended up going all out. Here's a picture of my rusty battery box before Its fixed.
post-11334-0-13888300-1384096346_thumb.j
zanepetty
Wire brushing my trans down to metal. And I got my girlfriend to learn how to use a grinder today! Worked out pretty good.
post-11334-0-65498500-1384122994_thumb.j
ol550
Guess that makes her a keeper. :handgestures-thumbup:
zanepetty
She complains sometimes when I work on my tractor but today I said: " Ill give use one task and that's to start cleaning this trans up and you gotta help today to see what its like!" She agreed and actually had a good time haha. Plus she loved riding my reactor before I tore it into a million pieces so yes, she's a keeper .
zanepetty
Here's a few more pieces that got finished up today. I did my trans with a good trusty grinder and cup brush from good ole harbor freight. The other pieces I blasted using my sand blaster from harbor freight. And soon I'll paint them with my paint gun from harbor freight. Gotta love that place.
post-11334-0-19647000-1384378264_thumb.j
post-11334-0-55368700-1384378284_thumb.j
stevasaurus
Starting to look real good Zane...and getting some help on the side...priceless. :)   It really is a sharing hobby...very cool. :)
  • Similar Content
    • eo1bart
      By eo1bart
      Looking for a gearbox with 1 1/8" axles for my 312. Ok if it needs rebuilding.
      Located in the New England area
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • giant_g2
      By giant_g2
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
