alan8three73
How to free a stuck D250 clutch
alan8three73
I have (2) D-250's. Two weeks ago i found *both* of them had their clutches sticking. They were both working fine the week prior. I figure the humidity must've done something. So I tried every trick in the book to get them free - jamming against a tree, pressing/depressing the clutch pedal, quickly accelerating, braking and gunning the throttle - nothing worked.
Then I found a trick that frees the clutch in 10 minutes - with a paint scraper! Underneath the tractor, the oil pan has an inspection window. If i hold the clutch pedal down with my hand (while underneath), I can stick the paint scraper in between the flywheel and clutch plate and free it up. Rotate the motor and repeat in the 3 sections of the clutch that are accessible through the window, and voila! After about 10 minutes I can get it free! It worked like a charm on the one, so I did the same on the 2nd, and now they're both free!
Hope this helps folks out in the future who get their clutches stuck!
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • eo1bart
      By eo1bart
      Looking for a gearbox with 1 1/8" axles for my 312. Ok if it needs rebuilding.
      Located in the New England area
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • giant_g2
      By giant_g2
