AETD
C-175 Kohler engine battery charging
AETD
Hello,
I I have a c175 with a kohler engine.
My battery is not charging when the engine is running...
One 'expert' is telling me it should charge when the engine is running...
Another 'expert' is telling me not all enginesz have a charging system...
How are these engines charging?
thanks
groundhog47
Not in any way an expert, but if electric/battery ignition, there is a stator winding under flywheel that induces a charge current back to battery. If you have a working amp meter on your dash tower it should show a + needle deflection (maybe jumpy). You might find a good wiring diagram in manuals section for that particular stallion. Off hand don't know if has a fuse in circuit, but would suggest give a look see at diagram to be sure.
This may be same as yours   does show a fuse (25a) in charge circuit.
Edited by groundhog47
Jeff-C175
If you have the original Kohler KT-17 twin cylinder engine in your machine, you DO have a charging system.
Do you own a multimeter and know how to use it?
AETD
Found what was wrong.
D5ECF603-D2FD-49A2-ABA2-741349428A74-846
Jeff-C175
What the heck does that mean?  Is that supposed to be a link to a picture?  It doesn't do anything, tries to load something, then freezes.
Are you in Belgium?
Edited by Jeffpicks
SousaKerry
Picture works on this end...
What is shown is the voltage regulator for a kt17 and it is disconnected.
Jeff-C175
It's working here now also...  originally all I got was a string of numbers.
Yes, voltage regulator / rectifier.
In addition to being disconnected, terminals appear to have some corrosion.  Try to carefully clean out the terminals inside the plug with some contact cleaner before connecting to new regulator.
Edited by Jeffpicks
AETD
Thanks for the tip,
Did clean them with contact spray.
Works like it should.
The old battery is not holding more than 9V after a night of charging. so have to replace that.
At least i know the new battery wil be charged 'onboard' while mowing.
Thanks for the help
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
