AETD
C-175 Kohler engine battery charging
AETD
Hello,
I I have a c175 with a kohler engine.
My battery is not charging when the engine is running...
One 'expert' is telling me it should charge when the engine is running...
Another 'expert' is telling me not all enginesz have a charging system...
How are these engines charging?
thanks
groundhog47
Not in any way an expert, but if electric/battery ignition, there is a stator winding under flywheel that induces a charge current back to battery. If you have a working amp meter on your dash tower it should show a + needle deflection (maybe jumpy). You might find a good wiring diagram in manuals section for that particular stallion. Off hand don't know if has a fuse in circuit, but would suggest give a look see at diagram to be sure.
This may be same as yours   does show a fuse (25a) in charge circuit.
Edited by groundhog47
Jeff-C175
If you have the original Kohler KT-17 twin cylinder engine in your machine, you DO have a charging system.
Do you own a multimeter and know how to use it?
AETD
Found what was wrong.
D5ECF603-D2FD-49A2-ABA2-741349428A74-846
Jeff-C175
What the heck does that mean?  Is that supposed to be a link to a picture?  It doesn't do anything, tries to load something, then freezes.
Are you in Belgium?
Edited by Jeffpicks
SousaKerry
Picture works on this end...
What is shown is the voltage regulator for a kt17 and it is disconnected.
Jeff-C175
It's working here now also...  originally all I got was a string of numbers.
Yes, voltage regulator / rectifier.
In addition to being disconnected, terminals appear to have some corrosion.  Try to carefully clean out the terminals inside the plug with some contact cleaner before connecting to new regulator.
Edited by Jeffpicks
AETD
Thanks for the tip,
Did clean them with contact spray.
Works like it should.
The old battery is not holding more than 9V after a night of charging. so have to replace that.
At least i know the new battery wil be charged 'onboard' while mowing.
Thanks for the help
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Seat, New! Universal Garden Tractor / Riding Mower Seat
      This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
      I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
      This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
      $49.00  Call Tim @ 1-313-460-8858     (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
      This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
      The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
      $140.00 O.B.O. Call Tim @ 1-313-460-8858        (No Shipping, Local Pick-Up Only)
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
