Hodge71
C-160 8 speeddrive belt
Hodge71
I did a quick search for the number on this belt and I'm coming up blank. Actually I'm coming up with so much it's hard to wade through it all. I'm going to look at a C-160 8 speed tonight I found on CL. It has a broken belt and I just would like to figure out a cost before I check her out. Give me more bargaining space....ya know. Guy wants $400 for just the tractor but after speaking with him extensively today it sounds to be more of a $200 machine. I guess time will tell...maybe theres a new addition coming to the herd.
rmaynard
Part #7473
Hodge71
Thanks Bob!! I appreciate it
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get a big diesel swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
