Dana Bennett
1982 C-195 60" mowing deck, need parts/help/info
Dana Bennett
 Hi everyone,
      Ok, first post here! If you didn't see my introduction post My name is Dana Bennett and I live in Forestville, NY.
 I have a 1982 C-195 that I bought about 11 years ago and have used it a LOT to try and upkeep my 4 acre lot around my 1860 farm house. I've had many problems over the years and fixed them the best we could.
   My current issue is the 60" mower deck. A few years ago I already had the center pulley and hub replaced as well as the tensioner pulley twice (incorrect V pulley was installed when it should have been a flat one). I use to have the bigger repairs done at a local and VERY good shop (Montes) but with money becoming more tight over recent years we (my older brother Al lives with me) try to do the repairs ourselves.
    Right now I need to replace the center hub again, replace the tensioner pulley again and the tensioner arm can lift right off its shaft if I pull on it. About 2 years ago while trying to help out one of my neighbors by cutting their overgrown yard I hit something, this loosened the center blade and caused the blade to wear INTO the shaft. Brother Al shimmed the blade (brought the blade level with a good section of shaft) and retightened. Came loose again this year and now the groove of course is worse. Brother Al again reshimmed and tighted it again, it is working for now but we really should replace the hub/shaft because I'm sure it will continue to get worse, and who wants a blade shooting off a running mower?? yeah, NOT me!!! LOL!!
    Ok, first off, can I only get USED parts to repair this deck?? any suggestions on where to buy them??
     Has anyone fitted one of these older decks with modern NEW easy to get parts??
  We depend greatly on this mower and very much need to keep it working properly. It's old but I could never affords to replace it with anything comparable. all the parts/repair manuals came with it when I bought it, those have helped a LOT!!!!
      Thanks for any and all help with this issue!!!
            Dana,
AMC RULES
Dana, for the parts you're looking for...
try sending a PM with your needs to a couple of our :wh: parts venders here on   :rs:
Either of these guys, Kelly or Jordon should be able to help you out.   :handgestures-thumbsup:
http://www.wheelhorseforum.com/user/85-kelly/
http://www.wheelhorseforum.com/user/1653-jdog-kustoms/
Edited by MAYHEM '13
baerpath
If you get down this way I have 2 so so decks that are usable and 3 near perfect ones. I'm in Canajoharie not to far from Forestport
stevebo
Parts are no longer available for them (spindles). I found a fellow member who had a few nos shafts for it that I bought for good money. If I were you I would take Baerpath up on his offer. I have seen a few of those decks and they are nice for sure.
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
