jphickory
New Tiller for C-121 Auto.. need info please
jphickory
Hi,
I'm new here.  I own a 1979 C-121 Automatic.  I work a large vegetable garden and found a used Wheelhorse tiller for sale locally.  The gentleman I purchased it from assured me it would work on my tractor.  The tiller has no ID tag so I'm unsure of the model number.  It came with the mid-mount pulley system and belt.  He also gave me a weight that will connect to the front tach-o-matic hitch.
The tiller looks similar to the 36TL04 model that I saw in the manuals posted here.  It has a continuous hinge on the shield flap - not three pins like some I have seen.  My questions are:
1)  I'm missing the lever (rockshaft?) and other hardware that goes under the seat that the cable lift attaches to.  Anybody know where I can find
     these parts?
2)  I'm missing the cable lift, clevis, trunnion etc..  I see some similar looking parts are available from Toro but I'm not sure that they will fit my setup.
     Any insight here on how to get the correct lift cable parts?
3)  I'm missing the heavy lift spring, bolt eye, bracket and nut that connects to the tiller hitch.  Again, I see some similar looking parts available from
     Toro but not sure if will fit my tiller.
I really appreciate any help someone might be able to offer me.  If I need to post pictures to help someone better understand what I have please let me know.
Thanks,
John in Missouri
gwest_ca
The model number for the 1979 36" tiller is 97-36TL01
Replaces RT-366, RT-367, 7-1211, 7-1251, 7-1252, 67-36TL01, 77-36TL01, 77-36TL02, 87-36TL01,
Replaced by 07-36TL01, 07-36TL02, 07-36TL03, 07-36TL04, 07-36TL05, 79370
The clevis hitch is 8-5514 but needs to be entered as 85514 at Toro
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
Garry
dennist
PM sent...
dcrage
John
I just this year purchased all of those parts (new) from my local Wheel Horse dealer -- A few of them they didn't have in stock and were purchased from Toro -- So try the local dealers that used to be Wheel Horse -- I was suprised at what mine had in there storage areas -- (This purchase was NOT cheap, but I am pretty sure I have the correct stuff)
PS -- Where in MO are you located
jphickory
Thank you guys for the information that you have provided so far.
Garry - thanks for the info.  It looks like some of the parts of the hitch assembly are not available anymore.  Also, how do I confirm this hitch will work with my tiller?
Dennist - PM sent
Dave, I live in unincorporated St. Charles County in the Defiance, MO area.  Please let me know what dealer you found some of your parts.  I'd be very willing to take a drive to obtain some of the needed items.
dcrage
John
I got them in DeSoto (Mueller Motors) -- I think I got the last "rockshaft" that they had -- They were kinda suprised when they came up with it -- Anybody know who took all of the stock from Norm's Wheel Horse Barn (St. Charles) when they went out of business??
gwest_ca
Dennist - PM sent
I have no hands-on experiance with these tillers. Have to rely on what I read. The clevis hitch is not used with the tiller but the lift hardware is. When a modification was required Wheel Horse put together "service assemblies" that contained the necessary parts to complete the conversion. These kits are no longer available and seldom did they list the part numbers of the contents of the package. I should have explained why I included the clevis hitch page. Here are some service bulletins on making the different tillers fit the different tractors and others. Hope I have not missed any.
Garry
brandonozz
John,
There are several threads on here on how to make your own cable and rockshaft.  There is also a thread where someone just mounted a pulley to route the cable over to run to their hitch or tiller.  I know there are some who feel they need the assist spring for lifting the tiller but I have never had it and have no problem lifting the tiller and I'm no 800 pound gorilla!
If you decide you need a rockshaft I may have what you need over here in Tulsa if you ever come this way.
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
