tommyg
Fitting a rear discharge deck to a C125
tommyg
I'm looking at bidding on a rear discharge deck to fit a C-125. The model number (I think) is A2MR02-37143 27. It's 42". Just trying to find out if it will fit, but I can't seem to even find this deck on the Toro site. Can anyone help?
gwest_ca
The closest model numbers I see
to A2MR02 are
75-42MR02 (1977)
95-42MR02 (1979)
05-42MR02 (1984)
The 37143 serial number if correct is close to the 1979 model 95-42MR02 and fits the C-Series.
The 27 may be part of the 4-digit Julian build date.
If you get better numbers let us know.
Garry
WH nut
It will fit
Jeff-C175
I'm betting that the " A " at the beginning is a " 4 " ...
tommyg
I think you're right. He said it was really hard to read. Thanks!
otrelwood
anyone know what belt number for the mule drive / drive belt
Wishin4a416
I just did the same thing. Went from side discharge to rear. Oops. I think I quoted the spindle belt length.
Edited by Wishin4a416
gwest_ca
Drive belt for 42" rear dischage deck on a long frame tractor
Toro 102741 {HA/Ax96.6"}
6638BR Gates 17/32"x96-3/4" Wrapped
6638BR Napa 17/32"x96-3/4" Wrapped
Garry
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
