Jeff-C175
Yet another axle seal - C175 Auto
Jeff-C175
Fortunately, the axle steel being much harder than the cast iron hub caused the majority of the wear to the hub itself, some 50-60 thousandths as I recall.  Wear to the axle was limited to only 2-3 thousandths, and only at the ends of the hub because of the way it was wobbling I suppose.  The 'center' of the contact area was maybe worn 0.001 or so.
I have to confess that I did spooge a bit of the 660 onto the axle shaft itself to take up some of this 'slop'.  I might kick myself for this if I ever have to remove that hub, so hopefully I won't!
I cleaned up the area around the keyway with a flat file and some plumbers sanding cloth strip just to knock off the sharp edges that were raised from the key banging around in the slot.
Before sliding the seal on I covered the key slot with electrical tape.  Once the seal is driven home it's well clear of the keyway so there are no worries about it being damaged once installed.
By the way, I like the OEM seals MUCH better than the 11124 replacement seals.  The OEM seal actually has a small reversed 'lip' on the OUTSIDE toward the hub, in addition to the regular lip pointing in toward the tranny.  I believe the purpose of this small lip is to exclude dirt from working it's way in.  I read a few application notes from Timken SKF that indicate this is the purpose and they have a seal line with this feature.
If I HAD to use the 11124 seals (which we know are HALF the width of the OEM), I would strongly consider installing TWO.  But I think the inner one would be installed in the normal fashion and driven to the bottom of the bore.  The second one I would TURN AROUND and mount backwards in order to keep out the dirt.  It might be a bit difficult to install and drive in backwards though, so it might be a dumb idea, but I bet with an appropriate size seal driver it would be easy enough.
Edited by Jeffpicks
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Seat, New! Universal Garden Tractor / Riding Mower Seat
      This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
      I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
      This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
      $49.00  Call Tim @ 1-313-460-8858     (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
      This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
      The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
      $140.00 O.B.O. Call Tim @ 1-313-460-8858        (No Shipping, Local Pick-Up Only)
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
