Clark  MC
Clark MC
Clark  MC
Hi, Trying to find out what kind of Wheel Horse i have. Do not know much about it other than it was my dads.I know he had it about 15 years . Mowed like a beast till about four days ago. The only thing i can find is the id number it is 16K802 it has the kohler 12 horse and the large twelve inch wheel hubs low and high range 8 speed trans.  Mowed great till i cut it off to change deck belt . Went to start it back andwill not start unless the clutch is pushed in when i go to let clutch back out the the drive belt smokes and will not move . I need help to id what kind it is so i start to see how to fix trans .
posifour11
Is it possible that the engine was swapped?
I think that model number belongs to a 76 c-160. 16 HP Kohler, 8 speed.
WH nut
If it was fine until you changed the belt then the belt is the problem. Go back and start from square 1. Remove the belt and compare to the old one.
Don1977
There is a safety switch at the clutch peddle and it's not supposed to start unless the clutch is depressed. The simple things first did you set the parking brake when you stopped
the tractor. That could cause it to smoke the drive belt. You have to depress the bake to release the parking brake. Was the tractor moving normal before you stopped it? Check your blade belt don't know how you could have jammed the transmission drive belt changing the blade belt but it's possible I guess.
KC9KAS
71-16K802 is a 1977 C-160 16hp automatic.
Clark  MC
Thanks for letting me know what the model and year is for my wheel horse very good to know now i have to see what is still makeing my tranny not want to work right . The only thing i know for sure is where the belt pully at the tranny will turn to a point then it feels like it tries to get stuck and with alot of pressure i can get it to turn the rest of the way.
  • Similar Content
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • BrianStasC-101
      By BrianStasC-101
    • FAST41
      By FAST41
      I am new to this group. I have my sons collection of Wheel Horse tractors that are definitely rare models. He still has one to pick up that’s dual wheel and was purchased from Peabody Coal Co. This is the perfect site to get involved with. The best advice comes from folks that are hands on.. had to be their own machine shop. Nothing compares to the knowledge in this group.! But my first topic is this 19hp Craftsman INDY 500 limited edition model. I was reading a topic on here about the 18hp and 20hp models, but cannot find a single replica of this tractor on ANY site or e-bay. We live near central Ohio, so I’m assuming it’s a regional release.The Briggs engine lobes like a medium cam in a V8. We thought it was an intermittent miss, but it’s not missing a bit. The engine is the strongest riding tractor I’ve ever operated. It will literally cook the deck belt in high grass before dragging the engine down. Very wide and lower to the ground. I never got the size, but the rearend is all tires.! Looks like a dragster from behind.. almost  gives the appearance of shortened axle tubes in a hot rod. Just wondering if anybodys ever seen this particular model. My next top is will be about the C160 total hydraulic Wheel Horse he just acquired. Claim they were specially made for snow removal.
    • Wendell
      By Wendell
      New to the forum, but not to Wheel Horse. I just bought a 314-8 on the gear shift pattern there is what Toro calls a spring shift control, my 312-8 doesn't have this The 314 is a 1999, what was the purpose for this. Thanks.
    • Bobbi Barroso
      By Bobbi Barroso
      Missing lift rod. Anyone know where to buy one or the dimensions to make one?
