W9JAB
SEVEN THINGS A NEW WHEEL HORSE OWNERSHOULD KNOW
MarkPalmer
Great post, especially the paragraph regarding engine speed.  A lot of people are afraid to run at full throttle setting because they think it is taxing the engine too much or is making it use too much gas.  These small engines are governed to a top speed.  If it’s governed to 3600 RPM, and you put it at full throttle setting, 3600 is as fast as its going to go, and it should stay there under varying loads.  It’s not really full throttle so to say, because the governor moves the throttle plate back to regulate the engine speed, so it’s not nearly the same as dropping the gas pedal of your car to the floor in neutral and killing it.  Full throttle setting provides the best power, best cooling for both cylinder and oil for maximum life, and the best efficiency.  I’ll admit I do use part throttle for puttering around the yard now and then so I don’t make so much noise, but for any work like mowing or plowing you need to open it up all the way.
-Mark-
KATO
:woohoo:  :greetings-clappingyellow:  :greetings-clappingyellow:
squonk
Wear shoes around the open PTO belts!!!!
Don1977
That full throttle on and 8 speed you better be real easy with the clutch if you don't want 600# of tractor in your face.
JackC
Even more important, wear pants and keep your fly zippered.
W9JAB, Thanks for the post and the reminders. We should have those made into the 7 commandments for wheel horse owners.
dsholler
I do not want to derail an excellent thread, but this has always bothered me. I have a "grabby" clutch (belt is worn, no doubt) and have popped it many times and gotten that rising frontend sensation, but there is no way I was anywhere close to actually lifting it high enough to turn over, and I doubt any of the engines we have in these things combined with the transmissions could do so, except if you had already jacked the thing way up.  Is this really a caution that can hurt you, or just something that can surprise you if you are not expecting it. ?
chevyaddict83
I do not want to derail an excellent thread, but this has always bothered me. I have a "grabby" clutch (belt is worn, no doubt) and have popped it many times and gotten that rising frontend sensation, but there is no way I was anywhere close to actually lifting it high enough to turn over, and I doubt any of the engines we have in these things combined with the transmissions could do so, except if you had already jacked the thing way up. Is this really a caution that can hurt you, or just something that can surprise you if you are not expecting it. ? I know on my c120 hydro, if you knuckle it, the front end can come up2-3 feet, giving you that "pucker" factor you thought you forgot. :o
Sent from my 416-8
thehorse
I always shift the machine at a lower throttle speed (8 speed) and also when engaging the PTO.
scWHhauler
Super great post :happy-jumpeveryone:
Trouty56
I flipped an 856 on me once. It can happen.
ericj
the front end may not ever flip over , most of the times it will spin but every now and then when conditions are just right.........
eric j
entropy
Thanks for the post, big help to a new owner. I ran my lawn at 2500rpm and seemed good, but then forum members chimed in about running at 3500rpm and sure enough the manual states just that.
tunahead72
Excellent thread, Joe, but there really should be EIGHT things to know:
8.  RedSquare is your best friend! :)
puddlejumper
I have never felt like one would come over with the mower deck on flat ground but a bare tractor. You better be carefull because there is more guys than just me that have reared them over backwards and that doesnt just apply to the manual tractors, I was being raunchy on a charger ten checking out the hydro and if I had not had a hold of the motion lever when it stood staight up and started over backwards it would have been on top of me but as luck would have it as I went back I pulled the motion controll lever into reverse and it liked to have jarred my eyeteeth loose when it slammed the front wheels back on the ground.
Irv
In the right conditions they can come back on you, especially if you're on and incline.
Jake Kuhn
never.....EVER mess with the springs on a jd 112 variable speed system! don't ask me how I know. :hide::ROTF:
There's a reason I have horses!
Edited by Jake Kuhn
KC9KAS
Very good information. Thank you Joe.
AMC RULES
Excellent information to include on a maintenance decal Joe.   :handgestures-thumbsup:
leeave96
Seven other things new Wheelhorse owner should know:
1. First tractor isn't the last one.
2. Second tractor isn't the last one.
3. Third tractor isn't the last one.
4. Fourth tractor isn't the last one.
5. Fifth tractor isn't the last one.
6. Sixth tractor isn't the last one.
7. Seventh tractor isn't the last one and you may need a bigger garage... ;)
Edited by leeave96
  • Like 5
Kevbo
Seven other things new Wheelhorse should know:
So true...
MarkPalmer
Remember the wheel horse clutch isn't really a clutch, just a pulley tensioner so it's ok to ride it a little when taking off in a high gear which should prevent front end lift.  Also, when you look at the HP vs. torque curves on small engines there is less torque available when the engine is at full governed speed vs. part throttle, thus wheelies on takeoff come more from the gearing and clutching than they do the speed of the engine.
-Mark-
papaglide
Regarding the wheel horse clutch: is it ok to ride it to control speed like when backing to an implement or trailer? Can any harm come from riding it to slow down around corners and such?
Lane Ranger
Great post thanks for sharing this valuable information to a "new"  Wheel Horse owner!
PS:   I would add -no need to mow the lawn in third gear at full throttle  !   THIS IS For MY Brother!!
MarkPalmer
I use the clutch quite a bit to control speed moving around things.  No real harm to be done, as stated earlier it's not really a clutch just a belt tensioner. The extra wear to the belt would be insignificant, and belts are relatively cheap anyway.
-Mark-
  • Similar Content
    • eo1bart
      By eo1bart
      Looking for a gearbox with 1 1/8" axles for my 312. Ok if it needs rebuilding.
      Located in the New England area
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • giant_g2
      By giant_g2
      Not sure on specific model. This 8 spd came attached to a plow I bought. It had some water in it for a couple weeks according to the prior owner. I drained it, sloshed some diesel in it, drained that, then filled with fresh oil. Spinning the input shaft by hand, I can see the axels turn. Hasn't leaked any oil. I'm not really interested in shipping, so I'd prefer local sales.
