Hodge71
14 auto deck questions
Hodge71
I'm looking at purchasing a 1973 14 auto and was wondering if someone here could answer some questions. The tractor is in great shape as you can see in the picturebut the deck and mid tach-a-matic have me scratching my head. The deck height adjustment or "quadrant" as Wheel Horse calls it looks nothing like my Dads 12 auto deck, and if you look closely at the mid tach-a-matic, it has a big handle on it. Again, nothing like my dads 12 auto. My dads looks exactly like my 416, just a different color because its a Toro. So is this tach-a-matic and deck  just a different model or option??
post-1339-0-50757900-1366675967_thumb.jp
jdog_kustoms
its the old style mid attach and deck with belt ran threw the mule
Hodge71
You have me lost Jordon. I have the same exact tractor except its a 12 auto. What do you mean its the old style mid with the belt ran Through the mule? My 73 12 auto has the same mule drive on it as this 14 auto. Are you saying that this is a pre 1972 deck on a 73 tractor?
jdog_kustoms
yes it has a pre 72 deck and mid attach the front attach and mule are correct for a 73 and up they have switched the mid attach to use the older deck
Hodge71
Oh boy. I wonder where I can get a post 73 deck 48 inch deck and mid tach-a-matic thats a s nice as this one is. Might have to do some hornswaggling and find someone that will trade. Having a pre 73 mid hitch isnt going to work with the 73 cultivator set I plan on putting on this tractor
leeave96
Can you post more pics?  I'm not sure you have a problem, but need a bit more look-see detail.
Hodge71
Its not that theres really a problem. I know the deck runs well and is sound. It was just completely different than the deck on my 12 auto which I knew was from '73. Jordon was nice enough to help me figure out that its a pre 1973 deck or "old style" tach a matic set-up. I was just hoping to get  the new style deck for it so that its correct
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
