B-8074
Deck size ?????
B-8074
I put the forward swept axle and 1" spindles on my C-175 along with gear reduction steering. My question does the KT-17 have enough power to run a 60" deck? I know it will fit, but my local dealer said I don't have enough power. I'm not convinced, but don't want to buy one if it won't work. Has anyone run a deck that big on anything smaller 20hp? Any feed back would be great. I need to get another deck ASAP. Thanks.
B-100 Dan
I think you would really be working the motor pretty hard with a 60" deck, unless you mowed about every other day.  An old Wheel Horse dealer told me years ago, that the implement that takes the most HP. and is hardest for the tractor to run is the mowing deck!!!
MalMac
Just my opinion but I think you would work that 17. I had one on my 520, it worked the 20hp sometimes if the grass was damp or just a little too tall. I did a great job but you could tell it worked the 20. Also that heavy deck is hard on the tractor. Wears the mid-point hitch and lift bar. If I remember right they had to come out with a heavy duty lift bar for the earlier 520's. Also I read were some of the 520's that used the 60 on a regular basis were having trouble with the frames cracking where the forward foot support bar went through the frame. Maybe some member will chime in here that knows more about it.
B-8074
Thanks guys. I didn't take into consideration on how it would wear on the tractor. Now I just need to find a good 48"deck.
  • Similar Content
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
