whizskier
Mowing Deck 1969 Raider 12
whizskier
 I have a 1969 Raider 12 tractor.  I need a housing for the clutch & pulley, as the ball bearings and the shaft for the clutch have broken. The local shop gave me parts for a much more recent tractor and they are worthless. The shaft has a notch in it that fits the rod to engage the mowing deck. I have no idea where to find parts.  Can anyone help me?
Don1977
Found the part no. and it's not available Part number 5197. Here is the PTO drawing: It's part 26 on the drawing. With the part no. you may try calling some other Toro Wheel Horse Dealers.
http://www.partstree.com/parts/?lc=toro_consumer&mn=83111%2C+PTO+Kit%2C+Tractor%2C+1969&dn=A_5169-51690001-0001
You can try Kelly  or Jdog in a Vender section also post in the classifieds that you need one as some other member may have one.
  • Similar Content
    • AndyZ
      By AndyZ
      Operator manual #A-5274
      Wiring
      6 pages 7.31MB
      Illustrated parts list link
      Use the 1970 parts list for the Raider 10 model 1-6051 and Raider 12 models 1-6251 and 1-6253 with the following exceptions
      For 1970 electric clutch use Electro 12 model 1-7255
      2 pages 282KB
      We also have the 1971 tractor parts manual that followed
      1971 Raider 10 model 1-0300 - (1-0300-6) - Uses HH100-115145C with magneto ignition (Engine oil capacity 2 quarts)
      1971 Raider 12 model 1-0310 - (1-0310-6) - Uses K301S-47407C with breakerless magneto ignition (This model also made in Belgium) (Engine oil capacity 2 quarts)
    • mmmmmdonuts
      By mmmmmdonuts
      My cheap-o walmart U1 battery is starting to bite the dust again (barely able to crank it over fully charged, and ozzing everywhere) after 3 years on my 68' Raider and I am looking into a new battery for winter as I now have a plow setup. I was thinking of either getting the original 22NF battery that came with it or running a mazda mita battery which is a U1 size. Is the AGM worth the extra money over the 22nF even in the smaller size? I think the vibrations keep killing the cheapo batteries and I am trying to make sure I can leave it out in the cold and not have a problem starting in the winter. It does get down to 0F or below zero every once in a while. I don't think I want to go all the way to a 22nF AGM as it is $200.
      Thoughts?
    • ohiofarmer
      By ohiofarmer
      I am picking away at the k series on the raider10. Basically the Piston blew through at the ring grooves as it appears the rings may have had too large a gap. I can feel a slight erosion of the bore where the ring gaps All lined up, but not even close to catching a finger nail.
      I am hoping just hoping out the bore will get it back to round close enough that a ring job will do .
      In any case I can measure the bore and report back. Discipline demands that I do not tear this engine down right now as too many things are taking up my time.
      Just hoping the gurus can offer a bit of guidance
    • davidtmercer
      By davidtmercer
      Just recently had a 10 pinion differential axle gears lose their teeth as shown in this picture from a post in 2014.
      Was wondering if others have had this happen and if they determined the root cause and corrective actions.
      I am considering replacing the two axle gears and five pinions that were destroyed but did not want the same thing to happen again.
      I assume the failure was due to a worn cylindrical spring that I also plan to replace.
    • 12 hp Kohler
      By 12 hp Kohler
      Been looking at a lot or Raiders and Chargers lately and was wondering if they all have LSD? I know most of them did but I was wondering if some of the later models might have had the Uni drives instead ?
      Thanks, Robbie.
