VinsRJ 723 #1 Posted February 26, 2013 (edited) Since making my fiberglass RJ hood I have been making a couple fiberglass parts here and there. Well I told one of my friends that when the resin cures... it can get pretty darn hot... to a point where it sometimes melts the bottoms off the platics mixing cup. As you can see it can get pretty hot! This was taken after it started to cool too. Edited February 26, 2013 by VinsRJ Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted February 26, 2013 Yes it can get HOT, I've been working with it on and off for 30 years more so years ago when cars used fiberglass not plastic Share this post Link to post Share on other sites
AMC RULES 37,196 #3 Posted February 26, 2013 (edited) Talk about hot... I bet you could sell those repro fiberglass roundhoods as fast as you could make 'em Vin. Edited February 26, 2013 by amcrules00 Share this post Link to post Share on other sites
can whlvr 994 #4 Posted February 26, 2013 i used a fair bit of epoxy resin when glassing,my first time mixing i made the mistake of putting it in a coffee can,well in about 5 minutes i had a 50 dollar paper weight Share this post Link to post Share on other sites
64s 83 #5 Posted February 26, 2013 Vin ,, How about some pictures of the hood?? Share this post Link to post Share on other sites
neil 2,410 #6 Posted February 26, 2013 We use Fibre glass resin here in UK to lay Flat roofs lets see the RJ hood Vin Share this post Link to post Share on other sites
VinsRJ 723 #7 Posted February 26, 2013 (edited) I'll add hood pics tonight... I'm also working on fiberglass RJ belt guards... I know, I know... not original but my thought process is a lower cost alternative until you are able to find and economical original replacement. Here is a vid with the hood in it... Edited February 26, 2013 by VinsRJ Share this post Link to post Share on other sites
stevasaurus 23,275 #8 Posted February 26, 2013 Real nice video Vin. can't wait to see this at the show. Share this post Link to post Share on other sites
buckrancher 2,694 #9 Posted February 26, 2013 Wish I had known you had that older 55 frame I could have traded you a early 56 for it and I could have used the early frame with tank mount for one of my projects Share this post Link to post Share on other sites
VinsRJ 723 #10 Posted February 27, 2013 (edited) Wish I had known you had that older 55 frame I could have traded you a early 56 for it and I could have used the early frame with tank mount for one of my projects Brian, I still have the tank support, all I did was nibble it off the frame with a die-grinder. Quick blast and it would be pretty much mint. I was going to put it up on ebay and see were it goes... interested? Edited February 27, 2013 by VinsRJ Share this post Link to post Share on other sites
