red tractor
315-8 Service manual
red tractor
Hi
I am looking for a service Manual for a 315-8 Tractor. Toro  no longer has them for download or to buy.I am sure there has to be a copy somewhere!
Hope someone can help Thanks.........
KATO
If your tractor is model 73450 Here is a link to try. if it's the wrong year you can change that at the top where it says
(change)
http://www.toro.com/en-us/parts/Pages/PartsDetails.aspx?mybeid=23711&serialNumber=220000001&modelNumber=73450&searchTerm=9lzIRv+p5zetpQyFgf8hmi1HtqApheTCLZkMap/TJifr4KsW+JAJzbIXw+xa+/ed
red tractor
Hi
Thanks for the reply !      that was for parts only.....
KATO
Did you see the tab beside it that says manuals ...there is several service manuals or demystification guides there.
red tractor
Hi Again
Yes I did...all the manuals are there but service Manuals....just My Luck...Thanks again......P.S. They due have the Manuals for the new style Toro..
rmaynard
Many service and maintenance items are covered in the owners manual. Have you looked at that?
red tractor
Hi Bob !
You are right !   Good call....But I need the service Manual for the preload & gear spec. for rear diff. Thanks for the reply......
KATO
That 315-8 is model  73450 ...correct???. If so it should have the same 8 pinion 8 speed 1-1/8 axle uin -drive
trans as MANY older wheel horse tractors. So this manual posted here in the manuals section may help.
  • Similar Content
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • BrianStasC-101
      By BrianStasC-101
    • FAST41
      By FAST41
      I am new to this group. I have my sons collection of Wheel Horse tractors that are definitely rare models. He still has one to pick up that’s dual wheel and was purchased from Peabody Coal Co. This is the perfect site to get involved with. The best advice comes from folks that are hands on.. had to be their own machine shop. Nothing compares to the knowledge in this group.! But my first topic is this 19hp Craftsman INDY 500 limited edition model. I was reading a topic on here about the 18hp and 20hp models, but cannot find a single replica of this tractor on ANY site or e-bay. We live near central Ohio, so I’m assuming it’s a regional release.The Briggs engine lobes like a medium cam in a V8. We thought it was an intermittent miss, but it’s not missing a bit. The engine is the strongest riding tractor I’ve ever operated. It will literally cook the deck belt in high grass before dragging the engine down. Very wide and lower to the ground. I never got the size, but the rearend is all tires.! Looks like a dragster from behind.. almost  gives the appearance of shortened axle tubes in a hot rod. Just wondering if anybodys ever seen this particular model. My next top is will be about the C160 total hydraulic Wheel Horse he just acquired. Claim they were specially made for snow removal.
    • Wendell
      By Wendell
      New to the forum, but not to Wheel Horse. I just bought a 314-8 on the gear shift pattern there is what Toro calls a spring shift control, my 312-8 doesn't have this The 314 is a 1999, what was the purpose for this. Thanks.
    • Bobbi Barroso
      By Bobbi Barroso
      Missing lift rod. Anyone know where to buy one or the dimensions to make one?
