rfhouser
C-165 No Go
rfhouser
Stevasaurus, the tranny went back together beautifully — thanks to your guidance! Those videos that you shared are indispensable  :text-thankyoublue: .
The proof will be in the pudding, when I get back in the saddle and tell it to giddyup!
There is no way to guide both shift levers up through the frame rails, because the brake cross-over shaft (from the brake pedal on the right to the brake linkage on the left)
is in the way. I will either take the tranny off once more and angle it down to try to sneak the hi/lo lever under the brake part, or I will have to dismantle the brake assembly
to get it out of the way.
But this will have to wait a week, as I am off on a photographic safari, north along the New England coast. Fenway Park tomorrow evening (I am, for what it is worth, a  NY Yankee's fan)
and in Maine for lobster by Wednesday. So it probably won't be until next Sunday that I have a chance to work this problem out.
If anyone else has run into this problem, I would love to learn just how you solved it. This whole project has been like a wonderful puzzle (and,so far, I don't have any pieces left over!).
WH854
You will not be able to get  the shifter under that brake crossover shaft without doing more damage than you need :angry-banghead:  (my advice is take the brake part out  it's much easily that way) been their and done that :thumbs: And I don't think the brake assembly was in before the transmission was installed at the factory.
Chas
Edited by WH854
stevasaurus
I would listen to Chas here...even the manual says you may have to figure it out with each tractor. :bow-blue:   Thanks Chas. :)
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Seat, New! Universal Garden Tractor / Riding Mower Seat
      This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
      I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
      This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
      $49.00  Call Tim @ 1-313-460-8858     (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
      This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
      The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
      $140.00 O.B.O. Call Tim @ 1-313-460-8858        (No Shipping, Local Pick-Up Only)
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
