rfhouser
C-165 No Go
rfhouser
Well, gentlemen (is this accurate? or do I need to be politically correct :angry-nono: and address you as Wheel Horse Lovers?), this is my first post and I am looking for your help.
I own two Wheel Horse garden tractors, an early 1980's C-165 / 8-speed and a mid-1990's 416-H. Both tractors are workers; I would love to restore the C-165,
but I am using it all the time! This past Saturday we were using the Black Hood with our 42 inch snow thrower (I live in northwest Connecticut, and we were digging out from
24 inches of snow), and the transmission stopped transmitting. My 19-year old son was operating it at the time, and I do not know if it was a coincidental failure, or if it was
a result of his being impatient and trying to move the snow with the transmission in the high range. Anyway, it just stopped moving. The motor was running fine,
and when I checked the gear shifter I could move it anywhere in the H-pattern, with the clutch engaged, and got nothing. No movement, and no grinding of gears.
I have read all the posts on this thread, and I am impressed with your willingness to help. Following the tips that I have read here, I jacked the rear wheels up off the
ground and gave them a spin. The differential appears to be unaffected. Next I tried to assess the input pulley so I started the engine and observed the pulley
spinning freely. I will remove and dismantle the tranny if I need to, but I'm hoping that someone here can maybe know what's not working right and perhaps save me
from going into the transmission case. All those gears and parts give me cause to pause. I have rebuilt engines, but I have never been inside a transmission!
Sparky
I would take a look at the key on the tranny input pulley, sounds like it might have sheared off.
Mike................
rmaynard
:WRS: Welcome. Plowing snow can take it's toll on a lot of mechanical stuff. But here are my thoughts.
The engine is driving the belt, which in turn is turning the input pulley on the transmission. However, is the pulley actually turning the input shaft. I have seen sheared woodruff keys on the shaft. Next, did you possibly shear a woodruff key on one of the axle hubs?
Sorry, MIke, you beat me to it
Edited by rmaynard
rfhouser
Thanks for the quick replies.
I checked to see if the input pulley was moving around the drive shaft — it wasn't. The shaft was moving at the same RPM's as the pulley.
I don't think that either of the keys on the axle hubs is damaged, since when I jacked up the rear and turned the wheels, they spun in different rotations.
rmaynard
With the the rear end jacked up, you can spin the wheels and each goes in a different direction. That is good and proves that the differential is working, but did you try it with the transmission in gear?
rfhouser
That's just it — it won't go into gear. When I move the shifter through the H-pattern, 1st, 2nd, 3rd gear and reverse, there is nothing there.
I feel a very slight clicking into place in each location, but it is not like the old feeling of going into gear. Could the problem be a broken shifter fork?
rmaynard
Can you get the shifter out? Here is a picture of what the shifter forks should look like when the transmission is in neutral.
rfhouser
I'll try to get to it this weekend.
rmaynard
I have seen it before, the ball at the end of the shifter will sometimes break off. That's a whole other issue.
Let us know what you find. I'm sure others will chime it with their opinions as well.
rfhouser
Thanks, Maynard.
I'll keep you posted.
racinfool40
Might also want to check the high/low shifter to make sure it is engaged in either high or low..It might have got bumped where it is not engaging.
Don1977
It could be the High - Low shifter fork that is broken. You should never change the High - Low shifter unless you are completely Stopped.
rfhouser
Thanks, Don 1977
I will try to check that out later in the weekend.
As I said, my 19-year old was operating the tractor when it happened, so I do not know if that
is what he did. It very easily could have happened.
rfhouser
Well, I thought that I would get to my 8-speed the very next weekend. NOT! Life in general, and the need to make a living, gets in the way. Anyway, last week I removed the tranny from the C-165 and brought it to my workbench,
where it sits. Today I started to take it apart. I have followed the dismantling procedure, but am stuck on splitting the case. The bugger is not coming apart easily, and I am afraid to do any harm by hammering on the case. Does anyone have any suggestions. Stevasaurus, are you out there?
stevasaurus
Yes...run a razor knife around the seam cutting the paint.  Find an edge that sticks out a little...usually around where the slot hitch is.  Take a sharp chisel  and nail it fairly good.  If you get an opening, stick something in there and work the chisel around.  The case is pinned on opposite corners and you are actually lifting up about 1/4 to 3/8" to clear them.  Make sure you have the shifter out and the shallow side of the transmission down.  do not be afraid to hit the chisel and also do not be afraid to run the seam with that knife.  I use a wood chisel that I am not going to use anymore for wood. :)
If you have rebuilt engines, this is an easy job with the help here...if you need any parts, we can set you up also.
Edited by stevasaurus
Rock farmer
I like to use a stiff putty knife. You can tap on the edge of hit with a hammer if you need to. Just work around the perimeter tapping as you go.
Joe
rfhouser
post-9523-0-39068400-1366765616.jpgpost-9523-0-40775600-1366765637.jpgStevasaurus and Rock Farmer Joe, thanks for your replies.
I followed your advice and was able to get the case apart. Once I removed the differential/axle assembly and the pinion shaft/bull gear assembly, I immediately saw the problem.
It looks like the high/low shifter fork broke off. I assume that is what it is. It is thinner than the two shifter forks that I can plainly see.
When I remove the remaining gear assemblies, I will have a good look at the high/low gear mechanism.
All the gears look to be in good shape, as do all the needle bearings that I can see, as well as the two 1533 ball bearings. So I think that all I need to do is get a new high/low fork
and new seals for the axles, the input shaft, and the brake shaft; and a new shifter boot.
From the photographs that I will attempt to attach, it looks to me that some water got into the case and mixed with the gear oil.
I do want to say what a comfort it is having access to this site and its very helpful members. It's a huge help to this newbie.
Here is a SHOUTOUT to :bow-blue:  Stevasaurus! :greetings-clappingyellow:
Without your videos on re-assembling an 8-speed tranny I may not have attempted to do this by myself.
The schematics in the repair manual are enough to scare anyone but a very experienced mechanic.
So thank you, big time.
I will keep you posted on my progress.
stevasaurus
Nice pictures and that trans looks very good inside.  Glad to be able to help.  Thanks :)
rfhouser
post-9523-0-82763800-1367061442.jpgpost-9523-0-74473900-1367061460.jpgpost-9523-0-91364900-1367061473.jpgpost-9523-0-16023800-1367061492.jpgWell, everything but the high/low reduction gear is out of the case. The broken culprit was indeed the high/low shifter fork.
My parts order is in and I will work on cleaning up the rest of the tractor while waiting for the parts.
By the way, is it best to put in the new seals before or after installing the axles and shafts?
Attached are some photos of the cases ready for the parts and reassembly.
And, once again, my thanks to all who have replied — and a special thanks to Stevasaurus for his helpful video.
stevasaurus
You can put the seals in either before or after...I like before, but your preference.  Just make sure all burrs are filed down on all shafts (ends and key ways) going through seals...it is not hard to cut the rubber and end up with another leak.  Using a piece of masking tape over the key ways and ends of the shafts is a good idea also.  Thanks for the kind words. :)
rfhouser
Stevasaurus, you are most welcome.
Your efforts in sharing your experience with the transmissions is very much appreciated.
rfhouser
Parts arrived from Toro, late yesterday. So, the reassembly begins.
rfhouser
Problem encountered :
the 8-speed tranny is assembled, the hubs and wheels are attached, and my son and I mated the whole assembly to the rear frame plate.
However, I am not able to get the high/low range shift lever back on the high/low shifter shaft.
When we disassembled the entire rear end, I remember that we punched out the roll pin and removed the hi/lo shifter before we removed the tranny from the frame,
as it appeared that there was no way to wheel the tranny away from the frame with the hi/lo shifter still in place.
So I figured the sequence is the same in reverse.
Does the tranny need to be mated to the frame with BOTH the shifters attached?
If so, the only way that I can see getting the hi/lo shifter in place — underneath the brake transfer mechanism — is to lift the tranny and wheels off the ground to create
a sharp enough angle to guide the hi/lo shifter under the brake cross-over shaft.
For those who have done this before, what is the best approach?
Thanks
WH854
I put the Hi-Lo shifter in after I had the transmission bolted up, then put all the brake hook ups after I don't think you can get it to go on any other way. :thumbs:
Chas
stevasaurus
Got to tell ya, I've never had the pleasure of putting them back in the tractor...except for my 702.  The manual says something about guiding the shift levers up through the frame rails when taking it out and putting it back in..  Looks like the factory has the shift levers in before mounting the transmission. :bow-blue:   Check out section V of the manual.
How did the trans go back together...it really looked nice inside. :)
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • giant_g2
      By giant_g2
      Not sure on specific model. This 8 spd came attached to a plow I bought. It had some water in it for a couple weeks according to the prior owner. I drained it, sloshed some diesel in it, drained that, then filled with fresh oil. Spinning the input shaft by hand, I can see the axels turn. Hasn't leaked any oil. I'm not really interested in shipping, so I'd prefer local sales.
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • BrianStasC-101
      By BrianStasC-101
