Whmaverick
Hydraulic cylinder question
Whmaverick
So I was plowing this morning and noticed the lift cylinder was leaking. So I took it off and it's the old style welded on both ends, so can it be rebuilt? Is it worth it? How much to have a shop do it? Should I up grade to a newer rebuildable style? Thanks in advance.
Trouty56
The later if possible. I've had one rebuilt (weld cut on a lathe and rewelded) and it still leaks.
Edited by Trouty56
Whmaverick
Thanks trouty56 any idea what I can expect to pay to have mine rebuilt?
KC9KAS
Can a replacement cylinder this same size be purchased? I have a couple leaking too....I was going to take them to a hydraulic rebuild place for an estimate....Maybe couldn't afford it!
Trouty56
Maverick.....I had a guy at work do it in the shop after hours.....he charged me 50 buck. That is the best I can tell you.
KC9....I was looking at a cylinder on surplus center....I may try to mod it and see if it will fit. I may need to put a stop around the shaft to shorten the stroke. They used something like I am thinking to adjust the tilt on a forklift years ago.
chev0545
take it to a shop that has a test station.i had one cut,replaced o-rings,welded it,then tested it,no leaks
KC9KAS
What did this service cost?
chev0545
he was an amish that just opened.$100 w/ hoses,he said it wouldn't be that cheap again.
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Seat, New! Universal Garden Tractor / Riding Mower Seat
      This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
      I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
      This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
      $49.00  Call Tim @ 1-313-460-8858     (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
      This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
      The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
      $140.00 O.B.O. Call Tim @ 1-313-460-8858        (No Shipping, Local Pick-Up Only)
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
