JoeDink
Can I still get a front bushing for a 10hp kohler starter?
JoeDink
Is there any place I can get a front bushing or the whole cover for a 12hp kohler starter for a 1975 wheelhorse c120? The bushing is pretty well egged out, and I can not find a place to get one. It seems these starters are pretty common, but man they run for a high price... Serial number- 0599424M030SM Any help appreciated, thanks. EDIT: I apologize, I dont know if it makes any difference but its a 12 horsepower, not 10.
TT
:WRS:
If you're fortunate enough to have a starter/alternator/electric motor repair shop close to you, I would check there first.
If all else fails and you need a starter, try here: DB Electrical website
Cole
Try Ebay, That's where I found one for my 10hp Kohler after I had dropped mine and broke the magnets inside :banghead: I was luckily able to get a used one for $35.00 with shipping
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
