rplosnak
Length of C-161 drive belt
rplosnak
Could someone be so kind as to provide the correct drive belt length on a C-161.
Guy I bought it from had installed new belt and said the burning smell was coming from new belt getting worn in??!!. Didn't believe that BS.
I took everything apart to check for rub areas. Finally found belt is jumping off the spring loaded pulley on the engage lever. Thinking new belt is too long? Partstree does not show length.
If I had correct length for part # 7473 I could try new belt from local TS. If not, do the springs weaken and wear out?? Thanks for any help.
CRE1992
Yes, the springs do weaken and wear out. They are not that expensive normally, like $10-15 a spring, however it is possible there are not many NOS springs left. Whenever I get a tractor, I replace the drivebelt, idler pulley, and springs for the idler tension and the brake spring.
-Charles
jeremi3210
I used a 5L84 belt from napa on my c121 auto.
gwest_ca
The original 7473 belt for gear transmissions is HB/5Lx81.95"
Garry
Don1977
If the belt won't stay on the first thing I would check is the idler pulley for bad bearings. The idler bracket should have a 90 degree bend at the top to stop the belt when the clutch is pushed in, it also keep the belt on the idler.
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
