Jake Kuhn
c120 snowblower mounting pics
Jake Kuhn
Hi guys, want to get my snowblower mounted to the c120 but I'm not sure how it goes on and if it is missing anything. Could someone please get me some pictures of how one mounts. Thanks, Jake
Callen
Jake,
In FAQ and mechanical tips under snowblower belt routing is some good pics of it mounted. It locks in, in place of the mule drive.
Jake Kuhn
Thanks callen, anyone have some pics of the rear? Don't know how that long rod mounts? Thanks, Jake
can whlvr
dont have a pic right now but the rod attaches to the hook on the blower,then goes to the bell crank,the opposite flange that the mower deck uses,a flag goes in the end of the rod and it connects to the crank,when you pull on the lift handle it pushes the flag and rod which pushes the blower up,a spring can be added to help lift the blower
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
