Rollerman
D250 questions
sparky6398
Thanks, that's great info on my machine.
56flatbed
Nice pic of a restored DS2500 on the Gutbrod website, but the driver is on the hood. :eusa-whistle:
Wally
C-101plowerpower
Wally
you mean this one?
Koen
brandonozz
Now that is one sexy tractor!
N2 Tractors
On 1/11/2014 at 3:06 PM, C-101plowerpower said:
since the d250's are pretty much the same as gutbrod 2500, parts can be found in germany
http://gutbrod-schrauber.de/ersatzteile-f-r-2500-s.html  (Bad Link)
http://ersatzteilhandel.jimdo.com/gutbrod-2500-getriebe/ if you open the pdf on that site you'll get an exploded view of the transmission (Bad Link)
http://ardiehl.de/Gutbrod/Gutbrod_2500_Benzin_Motor.pdf engine pdf
hope this helps
Koen
On 1/14/2014 at 1:01 AM, C-101plowerpower said:
The last two links are great for part numbers.  Thank you very much.  I need a starter and a water pump for my D250 with Ark 550 FEL and ARPS Box Blade set up.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • ccs002
      By ccs002
      Looking for a complete hydro pump for a D-160. Tractor is missing everything from the rubber coupler disc back. Also willing to buy a complete tractor for parts, the closer to Harrisonburg VA the better. Thank you.
    • tractorboy79
      By tractorboy79
      I was looking around on ebay and noticed that hydraulic actuators from John Deere 312, 317, etc models appear to be Identical to a Gt14 or d series lift cylinder. My question is would a new cylinder from ebay be able to replace one that is on a gt14 or d series?
      Images below of cylinders to show similaritys.
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
