farkin_Gary
Saving a 1076 (My first Horse)
farkin_Gary
Greetings;
I got a 1076 Wheel Horse tractor, mower deck, and snow blower for the perfect price. They are all three in pretty good shape, but have been stored outdoors without being run for maybe ten years. The tractor has the original 10hp Kohler engine. My plan is to put this pony and her attachments back into service. I don't need to make her pretty. I just want her strong and dependable again.
My first move was to buy a copy of the original owners/service manual. My next move will be to buy and install after market throttle and choke cables. After that, I'll refresh the fluids, grease and spark plug. Based on looking her over, I do expect she'll start right up.
At this point my first questions are as follows:
1.) The service manual shows a "speed control handle" on the right side, about even with the rear edge of the hood. The service manual also shows a "Cam control arm" (part no. 6123) on the right side. Neither of these levers appear to be present on this tractor. Did these represent optional features? Are these levers attached to the mower deck? (I haven't brought the deck home yet) This manual is also for the 1276 model. Could those levers have been for that model only?
2.) On the left side of the frame, near the front edge of the rear tire, there is a clutch brake. My first problem is that the manual doesn't identify that item for me. The clutch pedal does not link to that clutch brake, and doesn't look like it ever did, although it looks like maybe it should. How was that brake applied? It's a mystery to me.
What I need is a 1076 expert with photos of every possible angle of this tractor. If I can see pics of this tractor in fully operational condition, I can figure out what I need to correct. I'll be refurbishing this tractor out-of-pocket, and money is tight, so it's going to be a slow process but any help is appreciated.
As a side note, my current lawn machine is a 12hp Murray which is showing signs that it's time to retire (scrap) it. I want this Wheel Horse to become my replacement mower.
Thanks in advance for any help.
AMC RULES
From the model list and pict gallery.
1076 1966 Lawn & Garden Tractor 1076 Automatic Kohler K241AS-46333D 10 Sundstrand 3100077
:WRS:
Also...here's a general search of Redsquare, type in "1076" in the first line here.
http://www.wheelhors...h&fromMainBar=1
wheelhorse 1045
go to the photo section and you will find pictures of your tractor there
sorekiwi
Welcome to Red Square.
I have had a 1276 for about 3 years, its been a good solid old tractor for me.
The "Speed Control Handle" is just to tthe right of the dsahboard. It is your means of moving the tractor - to go forward you push it forward, to go back you pull it back. The further you move it, the faster you go.. You can see it in this pic of my tractor (with most of its clothes removed)
I dont have a parts list handy to check on the "Cam control Arm", but I am thinking that they are talking about the little lever down low on the right side that takes the tension off the belt when disengaged. Its hard to see it in the above picture.
Both of these levers are attached to the transmission.
The brakes on the hydro tractors arent really brakes at all. Pushing the brake pedal just returns the motion control arm to the neutral position, and thus the transmission does the braking.
So I am not sure what you are talking about when you say cluch/brake. - Maybe if all these parts are missing, someone has changed the Hydro to a manual transmission?
Callen
Do you have 2 shift levers between the seat and the dash?
KC9KAS
:WRS: Hope you enjoy and find answers to all of your WH questions.
Martin
hey, welcome to redsquare.....
im sure it would help you if some of us posted pics,
but heres a better idea. post pics of as much of your tractor as possible showing concerns you have. im sure some of us will also see things that maybe arent right or you need to change. someone familiar with this model is going to see small things that you may over look. the model you have is similar to others from 1965-67,( and later too) and theres quite a few of us that have models from those years.....
farkin_Gary
Thanks for such speedy answers. You're helping already! I will post a set of pics of my 1076 some time this weekend. There are two shift levers between the operator's knees, the four speed gear shift and a Hi-Lo selector. The gear shift moves freely and pops into all four positions. The Hi-Lo selector moves freely but doesn't seem to pop into particular positions. Of course, that selector might be dependant upon having the tractor running. I see from the pic by sorekiwi that I have a manual power transfer clutch on the right side of the engine - it's that long lever which engages and disengages the clutch just behind the muffler. I'll have to look into that speed control arm. Mine is obviously missing :eusa-think:
Martin
sounds like it has been changed to mechanical 6/8 speed at some stage and no longer has the hydro transmission.
you have 2 scenarios here,
one i mentioned above, you have a 1076 that has had the hydro swapped out for a 6/8 speed( i say 6/8 speed because it could be either one or the other with the two levers)
or two, you dont have a 1076 at all. parts with the decals could have been swapped from a 1076 at some stage. do you have the id tag still riveted to the hoodstand. it would be just under the dash....
what model does it have on it? thats not set in stone either, because just about anything is interchangeable on these models and if it has been changed to mechanical trans then the hoodstand may have been changed too. thats why pics are a good thing, im sure some of us can set you straight.....
i think that maybe scenario 2 is more the case here, that would have been way less work......
heres where the tag on those models should be.....
post-4321-0-48259900-1347723571_thumb.jp
farkin_Gary
Here are some numbers: On the dash stand plate: Model 1 03106, Serial: 772409. On the engine: Model: K 241 S, Serial: A 213730, Spec: 46333 D. The dash stand has numerous welds. The power transfer lever which goes to the clutch behind the muffler looks like a retrofit.
Here's the link to the FaceBook album I made of this tractor: http://www.facebook.com/media/set/?set=a.4369051501285.219167.1137884915&type=1
I'll try to make a gallery here, and/or host the pics somewhere else and hot link out from here.
farkin_Gary
Testing...
sorekiwi
OK, with a quick search, that model # doesnt make sense, but looking at the pictures it would appear that you have either a 1076 that has been converted to a manual transmission (transmissions swap and hoodstand/console) or maybe its a 1056 with the 1076 hood fitted..
The engine spec is the correct one for both the 1056 and 1076.
Either way with what you have, you should look for information on a 1056. Disregard anything I said earlier about motion control levers etc - that only applies to the Hydro (Automatic) models.
The Manual for the 1057 is in the "Files" section here, it should be very similar to what you have. Also take a look at Martins thread on the rebuilding of his 1257, there is a lot of great information and pictures in that thread.
Martin
i may be going out on a limb here but i think you have a 1067.
the spec number for the engine would be the 46333d, and the decals on the console are for a six speed and are correct for a 1067.
i think that at sometime the hood was replaced with a 1076 hood.
as far as the id plate, give us a nice close up of it, really hard to see in the pics, sometimes they are hard to read or who knows it might have been changed at some time..... :confusion-scratchheadblue:
heres a 1067 manual for you as well....
Tractor 1967 1067 #346.pdf
mike mentioned my 1057 build, you can find the link to it in my signature if you are interested......
farkin_Gary
I was talking to my auto mechanic today (a private operator) and I asked him if he'd be interested in putting my Horse back in service. He has the shop, equipment and knowledge to accomplish things that would be difficult for little ol' me. He expressed some interest and then he says "come look at this". Come to find out he has a beastly looking 16hp Wheel Horse in his back shed. He picked it up for $100. It looks great, and the engine is just busting out of it all over the place! It looks like a mid 80's vintage. He says he discovered that the rear tires are a different diameter from each other, and he thinks that difference was throwing the hydrostatic drive into a tizzy, which might be why he got it so cheap. I didn't catch the name of the engine manufacturer, but like I said, this pony looked like a real beast.
P.S. I'll be posting a close-up of my tractor's below dash plaque some time this week.
Cheers!
AMC RULES
We do like our pictures here Gary. :)
markjs
Cheers!
Sounds like a D160?
sparky6398
You have a very nice original 1267, even the steering wheel appears to be in great shape. Those 2 spook Steering wheels are hard to find in good shape. All it needs is the right hood/decals and a belt guard and you could show it the way it sits.
krazy_horse
Martin, That dash picture has to be one of the best looking tractors that I've come across. Is there any more of it on the Forun?
sparky6398
krazy_horse, Here is the link to his build thread.
  • Similar Content
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • giant_g2
      By giant_g2
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
