FrankinWNY
1979 C-111
FrankinWNY
I need manuals for a 1979 C-111 and an electrical diagram, This has the original B&S 11HP engine, tractor complete and in good condition except for the wiring that was comprimized to have a seperate grounding switch to allow engine to start and be stopped.
Thanks, Frank in WNY
Don1977
You have the wrong key switch. Don't know the part no. but ground lug is grounded to the switch case. Not sure it will work on your switch, I had a switch on my Briggs that I ran a wire from the ground lug to a bolt on the dash and it worked.
gwest_ca
You can download an electrical manual from Toro
https://lookup3.toro.com/request/request.cfm
Hope you have the 8-speed model 91-11B801. Use the word none for a serial number.
The operator manual listed is for the 1979 C-Series but the C-111 is not listed in it.
The parts manual shows a C-111 Automatic but don't think it ever got built.
Garry
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
