buckrancher
ANOTHER 701 RESTORATION from trailer trash to trailer queen
buckrancher
have the frame welded
also made a new steering suport
Brian
dclarke
Looks good, Brian.    :thumbs:
rmaynard
You are amazing.  :handgestures-salute:
bowtiebutler956
 You have serious skills!! :text-datsphatyo:
Matt :flags-texas:
buckrancher
thanks guy's
Don1977
I don't believe that steering support is going to break. :bow-blue:
SousaKerry
What you didn't machine a new fan gear out of a chunk of solid SS yet???? Kidding aside good work as always can't wait for Charlotte now.
buckrancher
put the engine back together eoungh to paint the block
I was very lucky I found nos .010 oversize piston and rings for the 2 7/8 bore size a new rod and a nos crankshaft I had in stock
Jake Kuhn
Very nice brian! :handgestures-thumbup:
rmaynard
And you were also lucky to find a can of Restoration Series IH Red spray paint as well.
VinsRJ
Dupli-Color Engine "Red" is the exact match to Restoration Series IH Red, it also has a higher temp rating.
Mike (MikesRJ) and I verified this... and he used it on his RJ's K90 with great success.
Edited by VinsRJ
rmaynard
There are 2 engine reds from Dupli-Color. #DE1653 is the correct one.
welderman85
your work is awsome
stevebo
Way to give it a half hearted resto... lol
buckrancher
yea I tend to go over board :woohoo:
Zeek
Nice job Brian, can't wait to see it in person!
buckrancher
pretty much have all my parts made
Brian
Martin
looks awesome, one day i want to see all the tins done in stainless too..... :thumbs:
Edited by Martin
Jake Kuhn
WOW! this one is really going to stand out at the show! Will it be at the charlotte show in august?
dclarke
Lookin good, Brian!
rmaynard
Wow. That is amazingly awesome.
Edited by rmaynard
bowtiebutler956
 I really can't wait to see this one done! :jaw:  :woohoo:
Matt :flags-texas:
Kevbo
Unbelievable...you are the man.
Horse'n Around
Brian, your tractors are truly works of art.
buckrancher
thanks guy's hopfully the weather will get better and I can get some painting done
  • Similar Content
    • Brad Schroder
      By Brad Schroder
      Looking for 701 (k161) parts. Starter/generator, right side belt cover, left side belt cover, air cleaner housing. Thanks
    • oliver2-44
      By oliver2-44
      This one was on Marketplace for quite a while with a hefty price tag.  I ask if he was flexible on price, Nope.  After a quite a while longer same question before I made the drive.  Come on up, maybe we can make a deal.  The rest is history, I didn't steal it, but I'm happy with the deal!
      Ya I know you want pictures, but there a little more interesting back story.  His granddad's business was Nicholson Machine and Equipment and he was a Wheelhorse Dealer in the 50's and 60's in Paris....., Tx  that is!  He sent me this picture of the glass window from the door to the business that he has framed.
      He also wrote me a short note about his Granddad's business.  So after his he passed, his dad gave the tractor to him. he's had it for quite a few years and said it's always been garage kept.
      So if a Dealer owned this for his own use and never sold it, and then it passed to his Son, and then Grandson, that would technically make me the 1st buyer,
        Ok so on to some tractor photo's
      beautiful double pulley belt guard front and center.  It starts with a spray of gas in the carb, but doesn't stay running.
      All there, nice and original, you can see a weld repair on the front of the belt guard,
      Here's the serial number @gwest_ca
      The plastic dash is intact and not cracked!
      My 1st old style split key.
      it still has the orignal Silverton Ags. They hold air, but their so hard they probable don't need any.  I wonder if their hard because they might still have calcium chloride in them???
      The hitch pin isn't frozen and the lift cable even works.
      Interesting decal plastered across the front of the hood.
      aluminum gas tank is fairly clean.
      Hood bottom tab has been repaired.
      topless view of the engine, needs a bath. The front tires are original and hold air, but have some splits across the thread.
      Homemade choke and throttle cable bracket.  The base of the engine has wet oil, so i suspect it needs some gaskets.
      Both axle seals are dry, but the input shaft and brake shaft seals leak.
      I've learned if the top of the transmission is filthy oily, it probable means theirs water in the transmission that has floated the oil out.  This one is clean so hopefully that's a good sign.
      Started some maintenance and a beautiful sight, not a drop of water, just black oil.  It shifts through the gears nicely so it will be interesting to see how it runs/drives.
      I'll gradually go all through it with my checklist.  701 Minor Overhaul Checklist.ods
      Then have to decide if I rub it down with linseed oil like it is, or buff with some steel wool or wet sand to bring a little more red out, then oil.
      How would ya'll put your finishing touches on it?
      I'll update this thread as I do maintenance on it and get it running.
    • wh315-8
      By wh315-8
      So just picked up a 701, obviously the engine isn't right. I have a 7hp Kohler to put on and will put B&S on my Speedex. Anyone ever seen a post come out on the right from the rock shaft? It rotates with the lift handle and has no holes in it. It was done up well, almost looking factory.
    • chompinthebit
      By chompinthebit
      Hi all,
      i bought this 1961 701 in fall of 2018 and restored it. I completed it in fall of 2019 and I wanted to show some pictures of before during and after I got it done. I did my research and tried to make this tractor as close to original as possible. The few exceptions are tires, wiring and the steering support. Not a perfect tractor but sure is nice enough for me.
      all stainless hardware
      Rustolium stops rust Primer
      Rustolium Regal Red enamel paint
      powder coated wheels and seat
      Glenn Pettit Reproduction dash
    • T-Mo
      By T-Mo-(Moderator)
      1961 701s
