wh315-8
Electric lift kit #84225
wh315-8
I am looking for this kit. It seems hard to find. I can find bits & pieces @ dealers but no linear actuator. Could someone send me the specs of this actuactor. I believe it was manufactured by Warner. What is the shaft size? How long is the run out? What is the amperage, and capacity? Any info would be greatly appreciated. I believe I have found similiar actuators but need some specs to know I am getting what I need.post-7987-0-27412500-1344784214_thumb.gi
sorekiwi
There is photo's of mine in the old photo gallery.
And there was a thread a while ago about dimensions and specs, I'll try to find it.
sorekiwi
wh315-8
Thank You for the thread, very helpful info. Now I have a better idea of what I am searching for..
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
