1maidenfan
D 160 (16 onan) choking out after 45 min.of use???
1maidenfan
OK guys, I actually had to mow my yard last week and today. Last week when I was mowing after about 45 min. the engine started acting like it was starving for fuel or the choke was on. It actually died on me :confusion-confused: I figured that since it had been so long since i had mowed that the carb got gummed up, so I cleaned the carb completely and changed the fuel filter hoping that would do the trick. Well had to mow again today and like last week about 45 min. into mowing and the engine starts missing out and wanting to die. If I turn it off and let it sit for about 30 sec's or so it fires right back up and runs for a few then does the same thing over and over :angry-banghead:
So I'm thinking fuel pump :eusa-think:
I'm also thinking coil :confusion-scratchheadblue:
I checked over the wiring thinking maybe a loose wire or a wire shorting out, nothing :scratchead:
Normal running condition the engine does not smoke at all, now when it starts running rough I'm seeing light smoke from both exhaust. Once it starts running better the smoke goes away :angry-fire: That almost makes me think I have valve troubles :confusion-shrug:
ANY HELP WOULD BE GREAT :text-feedback::help: :text-thankyoublue:
coldone
Check the fuel cap vent. If it gets clogged it creats a vacuum in the tank and dosent let the fuel be pumped.
Jake Kuhn
Mine used to do that when you put a load on it,but if you shut the deck off it would gain all its power back,reset the points and it ran fine ever since. Jake
JackC
If it runs OK for 45 minutes I would think the valves are OK.
Sounds like a carburetor or fuel delivery problem but could be electrical.
When I cleaned my D-160 ONAN carburetor I soaked it overnight and replaced the float valve and seat and followed the service manual for the initial settings for the needles. I also use clear fuel line just before and after the fuel pump so I can see if there is a fuel delivery problem.
If the fuel drains back over time after the engine is shut off the pump may be weak.
The reed valves in the pump loosen up over time.
I have had problems with a loose vacuum line between the crankcase and the pump.
The clamps on each end of that vacuum line need to be secure.
I use long nose pliers to get behind the tin to secure the clamps.
Here is a picture of the clear fuel line that helps diagnose fuel delivery issues.
JamesBe1
Wish I knew enough about onan's to offer an opinion. I would love to know the fix when you find out.
zeedubbya
My 520h was doing the same thing--would run for about 20 min and then choke out. I researched on here and learned of the lovely Onan valve issues so I removed the air cleaner and it was spraying fuel up through the top of carb and eventually the fuel "backwash" would kill it and it would smoke a bit too. I could operate it without the air cleaner and it wouldn't die but it sprayed fuel everywhere. I went ahead and adjusted the valves per a recommendation on here, and it runs great now--no fuel spray. I know your issue could be many things but try pulling the air cleaner off it and see if you have fuel spraying up through the carb. If it is I think you need to adjust the valves--it's a pretty quick process even if you aren't great with a wrench. I'm not and it only took about an hour. Let us know how it goes!
1maidenfan
Thanks all for the support :bow-blue:
I'm not really seeing any fuel spray out of the carb. I adjusted the valves at the begining of the season when I rebuilt the carb. Mine was actully spraying fuel before I done the valve job(took valves out and refaced/seated them) I tried running it with out the air cleaner for awhile(which is a BIG no no!) and it still did it. :banghead:
I am thinking more and more it is a fuel delivery problem, will check old posts on here as to which electric fuel pump will work with my engine. I know I have seen pposts on here about this.
I like the idea of the CLEAR fuel line , will be looking for some of that also.
Again, thanks for the support.
GOTTA LUV THIS SITE!!! :happy-jumpeveryone:
1maidenfan
Ok guys after some serious thought and curiosity I figured out what was wrong with my tractor.
Here goes...watched a short video that was posted on redsquare that showed how to reseat the reeds in your fuel pump. As I started taking fuel lines off, I noticed some thing that looked like sand :no: rewind to last week when first noticed problem, when I went to change the fuel filter I thought I seen some sand or some thing that came out of the fuel line :confusion-confused: well at that time just thought it was some thing already on the shop floor.
Ok, now today as I go to take the fuel lines off so I can check the fuel pump, there is that sand looking stuff :angry-tappingfoot: Ok whats going on is what Im thinking :eusa-think: Look at the fuel filter and its full of white sand looking stuff. Pulled the fuel line off at the tank and blew it out, all kinds of sand came out :huhs: Time to pull tank and check. Dont have any idea as to how in the world sand got in my fuel tank but their it was :angry-banghead: Actually looks like sand blasting media.
Cleaned every thing , replaced all fuel lines and fuel filter and :woohoo: the ol onan is running and running good.
Sand in the tank, who'd a thunked :confusion-shrug:
JackC
Could be the ethanol in the fuel doing strange things to the tank and fuel system that previously used pure gas.
When I cleaned the carburetor on my 520HC I found about a tablespoon full of stuff like you described.
Here is some reading on the things ethanol can do for an old wheel horse tractor that was built to run on pure gas.
Pure gas does leave varnish deposits over time and apparently the ethanol cleans if off the inside of the fuel tank and lines.
I just switched to pure gas ( I can by it in NY state) and started using Star tron based on the recommendations by an outdoor equipment and small engine shop.
http://mystarbrite.com/startron//content/view/14/37/lang,en/
  • Similar Content
    • Southern_Secret
      By Southern_Secret
      Hello fellow Horse Heads long time no post for me, life gets crazy & a lot of things change sometimes but anyhoo. So back a few years ago when I first got my 1994 314-H I had it at my shop going threw it. One of my customers walk past as im working and said, you know I think Iv got a Wheel Horse & im thinking "no you dont buddy". I give him my # to send pics thinking it was a big waste of time & after getting the pics I realized he did have a Wheel Horse! I hand shake bought it right there, asked him to bring it to my store & he said no problem. Well after almost 2 years it is finally in my orbit. I know very little about it other than his father-inlaw got it new and used it around his house moving snow and stuff. His father inlaw moved down south here when his daughter got married and gave the tractor to my customer because he had a farm & his the inlaw had no use for it anymore. Same with every barn find, "it was running when parked" 8 years ago, said one of the axel seal is leaking. Im happy and hope I can get it back in running order soon cause it is going to be handy around the truck farm!!
      I will post Pics as soon as I reinstate my membership
    • Swemill
      By Swemill
      Hi everyone!
      Long time since i was here and my old pics is gone from the forum.
      I just uploaded a movie with pics on youtube, and thought i could share it for you guys.
      I would love to get some comments on my Youtube channel, from you true Wheel Horse fans!
      Thanks and Best Regards
    • 87buickt
      By 87buickt
      Listing for a friend, late 70s I believe D200 deck and plow. Been sitting for a while, make reasonable offer, friend also has tons of literature he may part with, if Interested let me know
    • Nathan W
      By Nathan W
      Does this look factory for 1976
    • wh315-8
      By wh315-8
      Anyone be able to measure out the Top Link Bar for the 50” D Series Tiller?
      Just finished rebuilding a tiller, have a adjustable type but would like to put a original type on like the manual has listed.
