WoodMotorsports
Gasket identification needed. (C-160 Auto)
WoodMotorsports
I'm having a bit of a time trying to ID a gasket through the Toro parts viewer. What is the large aluminum housing on the hydrostat/transaxle called in the picture below?
You can see the corner of the gasket in my fingers, and it leaks pretty badly from the same spot.
smoreau
I think thats part of the drive motor. As for gaskets. try your toro dealer for some more info. Also some one here that knows more will most likely chime in and help
pfrederi
Gasket is 83-3760 still available for about $9.00 Really is a simple gasket if you choose to make it yourself. You will need a snap ring pliers to remove the cover.
After looking inside several Sundstrands I can tell you do not repeat not use silicone for a gasket
WoodMotorsports
Now that's fast service! Thanks gentlemen.
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
