SAM58
520H BELCHING SMOKE
SAM58
Restored a 1992 520H, 60" deck with 1600 hours, sold to a freind and he has mowed about 2 acres with it for two seasons, now has 1700+ hours and still starts and runs like a new one.
Yesterday he started it up and moved it about 30 feet, then he said it blowed a big puff of blue smoke. Did the old girl just belch?
Still running great but the smoke scared him. could it be the crakcase vent stopping up??
Looking for advise....
MarkPalmer
Under "normal" circumstances its either overfilled with oil when this happens, or the breather could be getting blocked. With an Onan engine having that many hours, (high, but not abnormal) I would investigate by removing the heads and checking overall engine condition if it hasn't been done recently as it could be a blue puff of impending death.
-Mark-
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
