1maidenfan
Onan BF 16 hp engine out of time??? spitting fuel out carb.
1maidenfan
I have an 16hp Onan twin in my D160 and It is out of time according to my service/repair manual. It reads that you have to use a test light to check timing and the timing mark on the flywheel. I checked this according to my manual and the timing is off by roughly 13*.
My question is...can I adjust the pionts on this or is it an internal issue? I have not taken the flywheel off to check the timing marks on the cam and crank. Do I need to do that or can I adjust it at the points?
Thank you in advance for any and all replys and info.
John
Reason I was checking this is that I rebuilt the carb a few weeks ago and it ran great for 2 mowings, the 3rd mowing didnt even make it to the yard, I pulled the air cleaner and fuel was spitting out the top into the filter housing.
Any ideas?
stevasaurus
Could be a stuck float or float valve, check the float for proper adjustment also. :)
1maidenfan
Ok, I adjusted the valve clearence, off just slightly, got the timing set correctly. Fired it up and it ran for about 1-2 min and flooded out again :angry-banghead::angry-cussingblack::angry-tappingfoot:
Ok, carb comes off once again. I do believe the needle is sticking open, not sure why a new one would do this but sure seams that way. :confusion-confused:
Will have to order a new neddle valve and seat :confusion-waiting: as no one around here carries onan parts. :eusa-think:
I did check the adjustment on the float and it's dead on (1/8") according to manual.
Will see what happens with another new one. :confusion-seeingstars: :confusion-shrug:
Herbl
Check to make sure the float is not taking on any gas, if the needle and seat are good then it's most likely the float..
Herb
1maidenfan
Thanks for the suggestion on the float. I replaced the old composite one with a new metal one and when I took the carb apart, again, I found liquid in the floats. I believe this is my problem. I have contacted the seller I purchased the float from so hopefully I can get it replaced.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
