Shiloh Red Rider
Gas Overflow
Shiloh Red Rider
I just replaced the throttle and choke cables on my "new" (1969) Raider 10 with a 10 HP Tecumseh motor. I also removed the gas tank and cleaned the entire area (had gathered some extraneous materials over the years). After replacing the gas tank and opening the shutoff valve, the engine obviously would not run properly. Quickly observed gas dripping from the air filter. I turned the mower off, and removed the filter...gas continued to drain from the carb. I turned the fuel off, and the leakage stopped immediately. With the fuel shut-off closed the tractor starts and runs perfectly. When the shut-off is opened the motor quickly bogs and fuel spits from the carb.
It's probably a stuck or sunken fuel float. Anyone have any tricks to un-stick a stuck float? Or is the only option a carb rebuild/replacement?
KATO
If there was that much junk in the tank then a rebuild would be the best way to go . However, if your float isnt
full of fuel (sunken), you just might be able to clean the carb out carefully with compressed air, by removing the
fuel line where it goes in to the carb. then remove the float bowl ,(it should be cleaned out anyway).Remove the
float pin and the needle will drop out with the float. Be careful not to loose the needle or its clip. GENTLY
blow air through the fuel inlet fitting being careful not to blow the rubber seat out of the (tecumseh) carb.
Reassemble and try your luck.
KEN
Shiloh Red Rider
Thanks Ken!
I'll give that a try. (The fuel tank didn't have any debris in it...the stuff I cleaned was on top of the cylinder and behind/under the tank. The tank itself was pristine on the inside, but the tractor has set for a while....so may have some laquer in the float system (I hope).) If the clean-out doesn't work should be a simple r&r for the float. Again, thanks for the tip!
Bruce
JamesBe1
I've been through that lots of times. Probably some debris is keeping your float needle from closing properly. Either that, or your float is leaking, but that would be a strange coincidence.
The quickest and easiest thing to try is to remove the fuel line from the carb and squirt carb cleaner in the carb fuel lnlet. If the float bowl is already full of liquid, it makes it harder to get the cleaner to the area where the needle seats, so it helps tremendously to remove the float bowl.
If that doesn't fix the problem, then you are best to take the carb off and dismantling it for a more thorough cleaning. You might even think about replacing the float needle and seat while you have it apart anyhow.
Shiloh Red Rider
Thanks Be1!
I'll get a can of carb cleaner before I remove the bowl to try to clean the float/needle.
AMC RULES
Hey there Shiloh :greetings-wavingyellow:
:WRS:
JamesBe1
Thanks Be1!
Keep in mind that this is a "quick fix". Whatever is blocking the float needle may go on to clog your main jet. Then again, it may not.
Just thought you should be aware of that. I haven't had that problem ever, but it obviously can happen.
Shiloh Red Rider
Finally got this one resolved. The primary issue was a pin-hole in the float. Once the carburator was off of the tractor, it became evident the fuel pump diaphram was in bad shape. It took a while to get a replacement. But after replacing the float, the valvel and seat, and the diaphram, the 10 HP Tecumseh runs like a top. Thanks to all for the help!
bowtiebutler956
Glad you got her up and running. :thumbs: One more thing :WRS: and :wwp:
Matt :flags-texas:
  • Similar Content
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
