JamesBe1
D-180 Front axle
JamesBe1
I have two D-180's One I got a few years ago with an FEL. Had lots of problems with it, but am close to getting it running with a donor engine and help from some of the great people here.
I was swapping the engine, and noticed a difference in the front axles.
Here is the front axle from the one with the FEL:
The two bolts on the ends have always bugged me, but not knowing any better, I let it slide.
Here is the front axle from the donor D-180
Obviously a big difference. The FEL D-180 seems to have a smaller axle on it. Anybody know what that might be off of?
I'm finding more and more that the FEL D-180 is an amalgam of parts from different tractors. I recently noticed that the rear wheels on the FEL D-180 only have five lugs, while the donor D-180 has six lugs. Checking the parts breakdown, I see that six lugs are the norm. Obviously the hubs are off of something else. Given that I like the AG tires on it, and the horror stories I hear about getting hubs off, I am planning on keeping the five lug hubs and tires.
Anyhow, I thought I'd throw that out there to see if anyone here had any thoughts as to why the axles might be different other than it being a frankenstein tractor. I'm wondering if I should go to the trouble of swapping the front axles since the one with the smaller axles will have the FEL.
James
Kelly
The bright red axle looks like a cub cadet axle, I'm thinking like a 1650 or something like that.
73-18 automatic
I agree with Kelly and the donor tractor has the correct axle the only difference is some had 3/4 axle's and other's had 1" axle's
JamesBe1
A cub axle??? Is that even possible? Wow.
I'm definitely going to have to swap the axles between the tractors. I never liked the way it sat in the front end anyhow. Sometimes I noticed that one of the tires isn't vertical. I hope the rims swap nicely. The ones on the bright red tractor are in much better shape.
This is turning out to be almost a never-ending quest to finish this tractor. Oh the humanity!
wheeledhorseman
James, that's going to be a really nice tractor when you finish it. :thumbs:
Re the axle, it's yet another example of :scared-eek: "Look what a PO managed to do to my 'D' " - when all these restos are done and dusted we ought to post a thread under that title as I'm sure there would be many contributions to be made.
On the plus side the photos led me to your album - don't know why but I've missed out on that till now. I'm looking forward to having a good look through tonight when I get home.
Andy
JamesBe1
Thanx Andy.
Yeah, I think a "Previous Owner" thread would be hilarious. Maybe make some grown men cry. Some of Jeff's pics were pretty scary.
Someday I am actually going to finish this thing. Being between job makes money tight and time cheap (it's usually the other way around). Good thing I'm a born cheapskate. I would rather rather source and replace a small component than to throw away and replace the next-higher-assembly.
My pics aren't all that great. Mostly lots of rust! There is one that I put there yesterday. It is the one of the bear that I tried to attach to an IM to you that made it blank.
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
