JamesBe1
K482 Crankshaft
JamesBe1
Talked to my machine shop this morning. The crankshaft that I brought in for regrinding won't make it as it's too far out round.
After talking to the machinist, my options are to have it sent out for $150 for welding and regrinding or find another crankshaft to have him cut down.
I brought up the point that buying a used one is a gamble as it might not make spec either, but the machinist says it is unlikely unless it was one with a spun rod. Not sure about that, but I decided to look around the interwebs for a crankshaft. Of course, Kohler discontinued the crankshaft. Not sure that I would want to buy from then anyways.
I am a bit confused as to what to consider purchasing if I decide to gamble on a crankshaft. From the manual, I see 22 different variations of the crankshaft. Does anyone know about the interchangebabilty of the crankshafts? The one I am looking for (for a Wheel Horse D-180, K482S Spec 35222B), is PN 277912.
There are several cranks on ebay, but for different type of K482S's.
Can any experts lend a hand?
James
pfrederi
Different end users specified different cranks from Kohler. Usually the differences were in the length of the shaft and the size of the hole tapped into the end of it. I am not that familiar with 482s but in the KT series even the diameter of the PTO end could change. (JD used 1" shafts WH 1-1/8
I would be hesitant to get one other than from the correct spec# motor unless i could first measure the exposed shaft, keyway and tapped hole.
JamesBe1
Thanx Paul. I have been finding out the same thing.
I found a Kohler Crankshaft reference Manual online:
http://smallenginesuppliers.com/html/engine-specs/kohler/crankshaft-reference.pdf
Perusing it shows how different all the specs are.
I think that the one I need Spec 277912 on page 3.8 will interchange with spec 277690-S on page 3.18
I would appreciate a different pair of eyes to look at it if you have a few minutes.
James
pfrederi
Should work James. 277690s is the crank from a WH D200. (Spec 53105A)
Nice find on the crankshaft manual.
JamesBe1
Did some more searching. Spec 277690-S was used on a Wheel Horse 20HP engine, and a couple of mowers by Heckendorn and Schweiss. All cranks references are discontinued.
Guess I'll probably have my crank send out for welding unless I get lucky somehow.
pfrederi
James I perused the JD Gravely and IH spec numbers for 532 engines. None of them used the type crank you need ...sorry
JamesBe1
Thanx Paul. Of course, there are no D200 cranks to be had on the net at the moment. Oh well.
You and others might find this of interest. I was looking up Heckendorn Mowers on the net as it has sorta a cool name.
Here is a page listing who makes what brands of mowers and tractors:
http://todaysmower.com/2011/riding-mower-brands/
pfrederi
At the rate the hydros seem to fail in D series there will probably be parts tractors/engines any day now. :)
JamesBe1
I checked the Kohler site. That crank was used on:
K523-53105 Wheel Horse 20HP
K582-36303 Heckendorn Mower
K582-36325 Heckendorn Mower
K582-36339 Heckendorn Mower
K582-36343 Heckendorn Mower
K582-36360 Schweiss Mower
K582-36362 Schweiss Mower
Ya know, it's really nice to have such handy access to information on the net. Not like the old days when you had to call around to different places and sometimes people would be able to look it up for you. 30 years ago, it would have taken me several weeks and lots of effort to get this much info.
At least I can now go right to the source of information on some items.
JamesBe1
Lol, at the rate I keep killing them too. Snapped off a bolt on the gear cover on my replacement engine. Then broke the easyout in the bolt. Took me hours of drilling and a now set of dull cobolt bits to clear it out. It's a little off center, but not into the case. I hope I got all of the easyout cleared out. Now I am waiting on a tap and die set to cut a larger bolt size into it. All I want is enough threads to securely hold a bolt in place (5/16?), and I'll be moving forward again.
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
