EdG.
Can I replace my Sundstrand with an Eaton hydro?
EdG.
I have an Eaton #700 015 with a date code of ‘L13E’ .
It came with the rear end assembly and nothing else,
but I don’t know what tractor it was for.
Can anyone decipher the code date (L13E) and tell me when this hydro unit
was made, and what model tractor it came on?
I’m thinking about trying to adapt it to replace my Sundstrand unit
in my 1969 Electro 12 which is shot.
The Eaton does say that it’s rotation is CCW. Haven’t checked the rotation of my Sundstrand yet.
Does anyone know if you can still get any parts for the Eaton #7?
I know you can’t get new needed parts for the old Sundstrand and all the used
parts that I have found for it are just as worn out as my parts are.
I need a Wheelhorse that isn’t afraid to do a little hard work but so far
my Horse keeps breaking it's leg and I can't get it to heal.
Ed
Kelly
I can't tell you for sure what tractor the eaton 700 is out of but they started using eatons in the early 80's, the eaton 700 is the light duty eaton, the eaton 1100 is the heavy unit, and I can tell you it will bolt up to your frame, BUT after that nothing will be a bolt on, I'm sure it can be done, but the hydro linkage will have to be fabricated, oh and little by little the eaton parts are getting hard to find new.
EdG.
Thanks for the info Kelly, would you happen to have a good 1100
complete for sale?
squonk
I have one in the classifieds from a 520 but I am in NY and shipping would be a killer. I could haul it to the show in Arendtsville if a certain Illinois resident wants to haul it from there. :eusa-whistle:
EdG.
Thanks Squonk for your offer ~ The distance one has to travel to get some parts is the problem.
I don't mind 100 mile (+ or -) journey one way but NY would be too much for this old body of mine.
I don't know of anybody going to Arendtsville, in fact I have only met a couple of RS members from Indiana.
Kelly does have a couple of 1100's but then he is 300 miles one way from me.
I appreciate your offer.
Ed
squonk
Ed
There is a member near you that is very likely going to the show. I'll see if he would be available to haul it. Mike
squonk
Ed, Ck your PM's :)
  • Similar Content
    • eo1bart
      By eo1bart
      Looking for a gearbox with 1 1/8" axles for my 312. Ok if it needs rebuilding.
      Located in the New England area
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • D_Mac
      By D_Mac
      Well...... what's too many horses ? Is to many when you have no more room in the garage so you have to start leaving them outside ? You can say you are "tractor heavy " but are you really ? Right @WHX??. I picked this up today. I'm not really a parts buying guy, unless I need them, but I saw this listed and you know. Love at first sight. Appears i just bought a 1969 Charger 10. Or parts of one. PO removed the original tecumseh engine and was going to install this 10hp Kohler. Well as you can see he didnt get far. Engine is on frame not properly secured and nothing else is hooked up. Nothing. Wires hanging all over. Parts off of it. Im not sure if i have everything. I also am unfamiliar with these " newer engines" that dont have the old starter generator.  Not sure what works and what dosnt. Just got it home. If you kind fellas can take a look at what i photographed and tell me whats missing or what i will need to attempt to get this thing running again or if I just should rob some parts from it. Wiring it will be very difficult for me. I have said 100Xs I'm a horrible mechanic and even worse electrician. What ever I decide to do with it your opinions will be appreciated. Thanks
    • giant_g2
      By giant_g2
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
