DuchApl
My first restore ever - of anything. 1975 C-100
DuchApl
Sweet!! Very nice job!! :thumbs:
I have a 1975 C-100 that I purchased as a parts tractor. It was all there except the engine needed rebuilt. I decided to get her up and running. When I get time this summer I'm going to start the restoration on it.
Seriously, let me know if you need anything. I think I'm going to rebuild the tranny on the donor, and I 've got a few body parts.
hm12460
So go ahead and get the second one when you can. Tell the wife it's for her.
Anglo Traction
Duch, If that result is your first attempt, then you've taken to this Habit like a Duck to Water!. From now on, your going to join the 'Picky Clan' and continually seek perfection whatever you work on next.
A new oven is a fair exchange for another WH Tractor!.
AMC RULES
Great job with your first, you do really nice work. :thumbs:
Nice photography too, but this is the one that looks like a factory advertisement to me. :text-coolphotos:
Thanks, Craig!
Hey we're practically neighbors.
We used to live in Medford, where are you located?
Ken B
You did a real nice job with your C-100. Have fun with it!
rmaynard
Great job :thumbs: It's still amazes to me to see how well these old gals clean up.
DuchApl
Thanks, Craig!
Way out west - in horse country, ironically - near Clinton.
Hydro
Very nice job neighbor! Love the reupholstered original seat.
No, totally original seat. After watching these things go for a hundred bucks or more on eBay, I had nearly given up and was ready to drop a dime or two on an upholstery job... Until I found another '75 C-100 at the LOCAL toro dealer. No engine but a nearly pristine seat and a bunch of other parts. $40. Alas, no headlight lens, and a badly pitted hood ornament. I need the clutch arm and idler off the donor, if I can EVER get the freakin' roll pin out.
Really nice work. Hope this helps you with the PTO
DuchApl
I agree, Maynard. Even the donor that has been sitting in the elements for years is still really solid.
DuchApl
Actually, it's the roll pin in the transmission clutch arm that attaches to the drive belt idler shaft. Every time I go out to the barn, I hit it with a little more PB Blaster and I've been doing that for a week - still not budging. Might have to try some heat.
DuchApl
You are exactly right. I see all sorts of things wrong with the finish that the "layman" wouldn't notice. And a second WH would give me a chance to rectify all those trials and errors. Kinda like the one perfect golf shot I once had and spent 30 years trying to replicate. And FYI, Wifey is an interior designer - I simply shudder to imagine what she would demand by way of her own Wheel Horse. Paisley probably.
COMMANDO6
The only problem with creating anything, is that you look back on it and all you see, are all of your mistakes. I build model cars, and when I'm done and looking at it, I notice the little glue spot or messed up paint. It really irks me. But to an outsider, such as us here on RedSquare, your work looks absolutely amazing. Congrats on your first restore!
tarcoleo
"Leave the wife, take WH." -Don Arcoleo
Rooster
Oustanding Work!
CRE1992
Nice work! congrats
massey
As the others have said already, it looks great. Congrats on a fine job. :handgestures-thumbupright:
SAM58
Looks Like You found your purpose in life!!
:woohoo::happy-jumpeveryone::happy-wavemulticolor:
Outstanding!!
Irv
Very nice work. You should be proud and so should Wifey! Better you spend a few bucks on bringing a tractor back to life than over a bar somewhere. I also have a 75 C-100 I picked up last year. Had to rebuild the tranny and I was going to keep it original but after seeing yours I may try to get it somewhat as nice.
DuchApl
Thanks for the props, Irv.
I was thinking "all original" when I started it, but, I'm a big Ohio State fan (I know this info will genuinely endear me to some of the members here) and I just couldn't resist a Buckeye color scheme on the engine. I think I'm going to have to get a couple of those buckeye leaf helmet stickers for the hood :)
post-4385-0-54657900-1334139508_thumb.jp
AMC RULES
Maybe apply your stickers to some magnetic backer so you can put 'em on and take 'em of as needed. :scratchead:
DuchApl
Good idea, if I was Michigan fan.
clyde
thats the trouble with us guys,you raise the hood and look out the whole tractor gets painted! :woohoo: awesome job by the way :happy-jumpeveryone:
Hodge71
Great Job. I started my 18 auto in the same way...eneded up as a complete teardown...its amazing how that stuff happens
wh414
Real nice :bow-blue: Excellent paint job.
  • Similar Content
    • Gcw804
      By Gcw804
      I have a WH 300 series with a Kohler Magnum 10 engine and I cannot for the life of me figure out how to get the choke cable and linkage set so it will work. The numbers on the engine label  are worn off the, so I cannot give anyone that information. Does anyone have a picture or can you head me in the right direction.
      My arm for the linkage assembly is set at 3 o'clock and 9 o'clock if that helps. There seems to be several different linkage rods for this engine.
      Thanks
      Gary Williams
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • Donavon1
      By Donavon1
      Project black Betty the diesel 1054
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
