rplosnak
Can 2 stage blower be lifted manually
rplosnak
Have a C-160 HYDRO with manual lift and a 37" single stage blower that I have modified into a "TALL CHUTE" model. Works well and is easy to lift with spring assist. I have weights and chains.
Would a 2 stage blower be too much to lift manually and would I be really have anything to gain in perfromance? It's just that with the single stage, unless there is an adequate amount of snow, it is not all that necessary and effective. In deep stuff and wet it works great with the modified chute and SILICONE!
Also is the added weight of 2 stage going to be more of a problem with steering until I lift the unit?
Thanks for any input. I am new today to the RedSquare but not new to WH. I have have had several tractors.
rexman72
a two stage blower is like have a boat anchor on the front of your tractor.I would assume that it takes alot more force to lift it up.
Forest Road
I had mine on my manual lift tractor for testing purposesIt asnt too heavy BUT it didnt have ant snow or ice buildup at the time. BTW I am keeping my single stage. Too many parts to break on the big dual.
Jeremy Watson
Welcome to RedSquare! Its alway great to have another member from Michigan. Don't have experience with the two stage myself but i have read about some guys doing it. They talk about the importance of the lift spring. Good Luck and Welcome aboard
Jeremy
hm12460
I think you should trade your current set up for a non-running John Deere 212, partially dis-assembled.
ericj
i have a 2 stage snow blower curenttly on a 520 hydro. but when i bought it it was on a 90 416-8 it don't lift any harder than a single stage. but you do need to add wieght, lots of wieght wheel wieght alone are not enough. i've added a brackett to the rear axel and 2 40 or 50 # suit case wieghts. it will throw snow 30 to 60 feet with no problems. it will even throw the wet slop at the edge of the street
eric
wheelhorsec85
I JUST BOUGHT A 2 STAGE , and it is farily east to lift with manual lift due to is pivit point and assist springs . a single stage is a lot worst . actually sucks lifting a single
baerpath
I us mine on a manual lift no problem lifting it Actually easier than a single without the lift spring
JoeMonag
I have a two stage on my 416-8 and I had it on my 310-8.
The two stage has a heavy spring that you preload as part of the instalation. I'm not a big guy 5'6" 150 lbs, and I find it easier to lift the 380 pound two stage with my manual lift onthe 416, than my 42'" dozer blade on my 310.
I have 55 lb. wheel weights on each rear wheel, with chains,and a weight box on the rear with 180 lbs of patio blocks. You need the weight on the rear to offset the weight of the two stage in the lifted position.
I haven't used it much this year, but last year we had a total of 77" of snow by now, and I have to tell you the 416 with the 44" twostage made clearing my 400' paved driveway a quick job.
I down loaded the manual from toro, Ihave PDF copies if you need them.
Joe in Norton, MA
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range. Edit: engine is not important, it’s going to get an engine swap.
      Thanks,
      John
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
