whfan74
On to the next one.............701
whfan74
Well the Lady Ranger is done and the 701 has been sitting in pieces begging to be put back together. We have had everything back from the powder coater for a while and dad was supposed to be doing this while I was doing the Lady Ranger. Unfortunately he ran in to some other things that took more priority so I am helping him along with this machine.
We need to really get cranking on this one as we are wanting to show it in one month at the show in Fort Wayne at the Coliseum.
Here is what it looked like when we brought it home...........
I worked on it a bit about a week ago..........
Stopped in for a few minutes tonight and decided to take a picture since I forgot to this weekend.....
The tins and belt guard for the motor are all done and powder coated. The motor itself is going to need a lot of cleaning and TLC before we can spray primer and paint. Hoping to get cranking on this one. Found out we need to get new front tires since the originals ended up falling apart. So we are leaning toward putting tri-ribs on the front.
stevebo
Looks great so far. If you do not mind, what is the cost to powder coat the entire tractor? Also, is there a universal color code for powder coating or does that vary like paint?
Sparky
Nice start! You even have the hard to find dual belt cover. Seems like you never take a break Scott.
Mike............
whfan74
Thanks Steve, it is a little dusty though from sitting in the barn uncovered. Big oops on my part but will be cleaning things up as we assemble more.
The cost for us to sandblast and powder coat this entire tractor............$140. :hide: That is including the tins off the motor, rims, and the rest of the tractor. The only thing not powder coated is the motor itself.
Yes there are codes for the different colors of paint along with the different manufacturers that produce powder. Our powder coater deals with 3-4 different manufacturers to order powder from. I can't remember the name of our color right off the top of my head but it may be IH red. I will check with him soon as I will be dropping off a 500 Special for him to do for my little boy next. Need to focus on getting this one done with dad first.
Now don't get me wrong I know we are getting one heck of a deal. But here are the drawbacks.......1. He doesn't do any filler like Martin does. 2. If we miss a ding or dent it get's powdered over and then we are stuck. 3. Powder in some areas where you don't want it so there is a lot of sanding, filing, and grinding happening.
But the good............1. The price 2. The durability (especially with the little kids around) 3. The price 4. Ready to assemble as soon as it is cool enough to handle 5. The price 6. No mess in the shop 7. Did I say the price???? :ychain:
Mike............
Yeah just ask my wife's opinion on that one!
can whlvr
wow,thats a great price,do they blast it too,and thats probally not even in the park of real cost would it,if so id powder them all
whfan74
Yeah the same guy does the blasting.
Blasting and powder coating together............final bill $140
Oh yeah......I forgot his name and his phone number too! :ychain:
can whlvr
man how could ya not powder it,o took me many hours of blasting on my c101,it seemed like 20 hours,again thats a real bargain
Jake Kuhn
Looks good Scott! You can't argue for a price like that. Jake
stevebo
Can you use the typical bondo filler prior to powdercoating? Is there a different type of filler? I assume powdercoating is much more forgiving then paint in terms of covering up smaller imperfections?
whfan74
Can you use the typical bondo filler prior to powdercoating? Is there a different type of filler? I assume powdercoating is much more forgiving then pain in terms of covering up smaller imperfections?
Hey Steve I am going to let Martin deal with this one. I hope he chimes in as he understands the powder capabilities a lot better than I do. My guy has only been doing it for a year and a half so I think there might be some new areas that we can explore in the future to give some better results. Not trying to be coy..........just leaving it to someone who can probably explain it much better.
Martin did mention in his 1057 restore that you can use some filler but have to start the oven out at a cooler temp. To do powder on bare metal you are in the 400 degree range. I believe Martin mentioned starting at 100-150 degrees if filler has been applied.
kpinnc
Well for 140 bucks a tractor, you're getting out cheaper than using premium paint.
Looks great so far Scott!
whfan74
Agreed Kevin.........it may not be perfect, but it is perfrect for me. I just can't pass up the cost. Even after the cost to have it done, buying the tractor, adding all new stainless hardware, getting a few new items that have been worn out from years of neglect it still adds up to a big cost. Thankfully this keeps it somewhat more manageable.
Thanks for the compliment!
stevebo
IMO it is not only the cost savings however the labor like you mentioned. I guess I need to find a good powder coater in this area ...
Martin
scott, what? another one already! boy youre running circles around us slow tractor building folk out here.... :ychain:
its looking real nice though, :thumbs:
steve, the bondo i use for filling is just the regular stuff. no. 265 i think.
ive had it a while and it was sort of used as an experiment to see if it would work or not. it handles the temp of the ovens fine. one thing im not sure of is if it 'gasses' in the oven or not. sometimes when painting porous materials,when in the cure process they will emit gas and if you have a gelled over coat of powder paint on the part, the air is going to escape through the paint, causing tiny bubbles. cast iron is the worst for this.
one way to reduce amount of gassing is to preheat the part, run it through a heat cycle. 400 deg f for 45-60 min. then let it cool and then paint it.
what ive been doing with the bondo is preheating the part, let it cool. then when im ready to paint it, put it back in the oven for 5 min at 400,( time varies on thickness of part). this should get it to about 100-150. then paint the part. you dont want it too hot, it gets too hard to regulate how much powder you are getting on the part as its glossing over when your painting it. just want it hot enough to 'stick' the paint and provide for the lack of ground charge that will occur with non conductive bondo or previous powder coat on the part.
powder is more forgiving on small defects, but if its a hole or small cavity big enough that you are painting over and you manage to get air trapped inside when painting, guess whats going to happen to the air when curing in the oven? like scott said, its a one chance deal to get the metal right, if you miss anything, you need to just deal with it or strip it and go over it again.
scott, does your powdercoater strip parts as well, if you need to redo something? not sure how big a coater you have?
if theres enough interest, i can start a thread on this stuff. i dont want to hijack this thread with my ramblings......
im no expert at powdercoating but ive been around it for the past 12 years and put in roughly 20,000 hours at any of up to 5 booths/ paint lines spraying this stuff. im still learning, the biggest challenges are painting the old tractor stuff with the rust and what ever else is lurking in the metal to screw you over. my 20,000 hours of production time is a walk in the park compared to doing the old stuff, because new parts is new, no rust, no dents, no bs to deal with. sure theres rework, wash machines not washing oil good enough and screwing with the powder, or hundreds of other things that can happen, but you can go weeks without any problems, and perfect parts...... but throw some old stuff in there for a customer, or my own red stuff! and just wait for the trouble to begin. i guess im being pessimistic as its not all bad, dealing with rust pitting is definitely a learning experience though.... :thumbs:
hope this answers a bit of the curiosity, like i said i will start a thread on the subject if theres enough interest and i will try to answer all the ?s there, if anyone has anymore. maybe some pics of the lines at work too.
right now though, i want to let scott get on with his tractor, theres probably another 3 or 4 he needs to get done before the summer season hits.... :ychain: :)
whfan74
Martin,
Keep on sharing what you have. I don't mind sharing a thread with you and help getting the word out about the positives and negatives with powder coating. Like I mentioned, my guy has only been doing powder for about 2 years. He does a really good job but I have to make sure I have my parts exactly how I want them before I send them to him. He just blasts, washes, and coats. If I need a weld job he doesn't mind doing a little of that either.
He has goofed or somehow something got in to the powder in the past and he will strip and start over free of charge. If something comes back that I am not satisfied with he will re-do with no questions asked.
I haven't had a chance to really sit down with him and learn more about the process. This is what puts food on his table and don't want to keep him from his work. So anything you can share with the rest of us is very beneficial. I know the rest of the group would love to have a thread dedicated just to this to weigh their options in the future. Like anything else it has it's drawbacks but as you can see for me I just can't beat the price.
Yes Martin I am on to another one and I have neglected to actually show one other that was going on the whole time during this. It is almost complete and maybe I will throw up a picture of it sometime soon. I need to get it cleaned up because it has become a definite dust magnet with the tornado that has been going through the barn.
But just to have fun with you.......I am bringing over my son's 500 Special real soon and going to get it torn down and over to my guy so I don't have to wait for it when I am done with these other two. Last time I talked to him he said he is swamped with stuff right now so I figure it might as well sit in line while I am doing something productive.
whfan74
And you are right Steve it really cuts down on my labor time. I just have tear down and reassembly time, which still can be time consuming but not nearly as much as going over my parts multiple times. Of course I have already mentioned filing, sanding, and cleaning threads from time to time. That definitely slows down reassembly but it is more than worth it in my book.
Ken B
Steve if you find someone let me know, I'm very interested in this as well. Not only does it sound like it cuts down on the cost and labor I'd be willing to bet it will cut down on a big mess of over spray all over my work shop as well.
COMMANDO6
:eek: At least you weren't riding it when they fell apart!
whfan74
Well like I said we haven't been slacking off this winter. The barn is a complete mess, but it is because we are trying to crank some stuff out. Here is what dad is finishing up. Unfortunately we need some fittings for the gas line and have been unable to find something that looks like stock so far. So if any of you out there have anything that might help us out, we would appreciate it. Or if you can point us in the right direction.........that wouldn't hurt either. The photo isn't that great as we neglected to cover it up and it is a little dusty along with being a crappy cell phone picture. At least it gives you an idea.
Jake Kuhn
That walk behind looks great scott! Have to agree you have been getting alot done this winter! :handgestures-thumbup: Jake
Ken B
Scott, does your high energy level come in phases? Sometimes I'm like you, getting tons of stuff done. Then there are times when I can't get off the couch!
Very nice walker, luv it!
whfan74
You hit the nail on the head Ken. There are some nights I get over to the barn and just start working and get in to a groove. And of course I have those other days as well......go out to the barn, turn on the lights, look around, and just want to walk right back out.
Now I can't take all of the credit, all of these things have been a two man job. Dad is plugging away on some of it as well. I am sure many of you get in to projects and wish you had another set of hands to get things done. Well in my case, I do have that luxury.
whfan74
Sorry for the delay between posts. We have not been able to put any focus on this project in the past week. It was weird not spending a Saturday morning over in the barn wrenching on something. Thankfully I am pretty sure I will get some time this week to get some things accomplished.
Thanks to all of you that are following along. My March 30th deadline is coming faster than I would like and it is becoming a little stressful. The motor is torn down right now and will get be getting some new parts to hopefully make this a nice running K-161.
This tractor is going to be a 20 footer unfortunately. It was neglected way to long and has some pitting. It may get some newer tins in the future but this will have to do for the mean time.
buckrancher
you want to use a product called lab metal instead of bondo
whfan74
Thanks Brian, I am definitely going to have to look in to that as I am very displeased with the results of the hood. I will see if our powder coater would be willing to strip it so I can do some body work on it. This will be a heck of a lot cheaper than trying to find a nice replacement in the future.
  • Similar Content
    • Brad Schroder
      By Brad Schroder
      Looking for 701 (k161) parts. Starter/generator, right side belt cover, left side belt cover, air cleaner housing. Thanks
    • oliver2-44
      By oliver2-44
      This one was on Marketplace for quite a while with a hefty price tag.  I ask if he was flexible on price, Nope.  After a quite a while longer same question before I made the drive.  Come on up, maybe we can make a deal.  The rest is history, I didn't steal it, but I'm happy with the deal!
      Ya I know you want pictures, but there a little more interesting back story.  His granddad's business was Nicholson Machine and Equipment and he was a Wheelhorse Dealer in the 50's and 60's in Paris....., Tx  that is!  He sent me this picture of the glass window from the door to the business that he has framed.
      He also wrote me a short note about his Granddad's business.  So after his he passed, his dad gave the tractor to him. he's had it for quite a few years and said it's always been garage kept.
      So if a Dealer owned this for his own use and never sold it, and then it passed to his Son, and then Grandson, that would technically make me the 1st buyer,
        Ok so on to some tractor photo's
      beautiful double pulley belt guard front and center.  It starts with a spray of gas in the carb, but doesn't stay running.
      All there, nice and original, you can see a weld repair on the front of the belt guard,
      Here's the serial number @gwest_ca
      The plastic dash is intact and not cracked!
      My 1st old style split key.
      it still has the orignal Silverton Ags. They hold air, but their so hard they probable don't need any.  I wonder if their hard because they might still have calcium chloride in them???
      The hitch pin isn't frozen and the lift cable even works.
      Interesting decal plastered across the front of the hood.
      aluminum gas tank is fairly clean.
      Hood bottom tab has been repaired.
      topless view of the engine, needs a bath. The front tires are original and hold air, but have some splits across the thread.
      Homemade choke and throttle cable bracket.  The base of the engine has wet oil, so i suspect it needs some gaskets.
      Both axle seals are dry, but the input shaft and brake shaft seals leak.
      I've learned if the top of the transmission is filthy oily, it probable means theirs water in the transmission that has floated the oil out.  This one is clean so hopefully that's a good sign.
      Started some maintenance and a beautiful sight, not a drop of water, just black oil.  It shifts through the gears nicely so it will be interesting to see how it runs/drives.
      I'll gradually go all through it with my checklist.  701 Minor Overhaul Checklist.ods
      Then have to decide if I rub it down with linseed oil like it is, or buff with some steel wool or wet sand to bring a little more red out, then oil.
      How would ya'll put your finishing touches on it?
      I'll update this thread as I do maintenance on it and get it running.
    • wh315-8
      By wh315-8
      So just picked up a 701, obviously the engine isn't right. I have a 7hp Kohler to put on and will put B&S on my Speedex. Anyone ever seen a post come out on the right from the rock shaft? It rotates with the lift handle and has no holes in it. It was done up well, almost looking factory.
    • chompinthebit
      By chompinthebit
      Hi all,
      i bought this 1961 701 in fall of 2018 and restored it. I completed it in fall of 2019 and I wanted to show some pictures of before during and after I got it done. I did my research and tried to make this tractor as close to original as possible. The few exceptions are tires, wiring and the steering support. Not a perfect tractor but sure is nice enough for me.
      all stainless hardware
      Rustolium stops rust Primer
      Rustolium Regal Red enamel paint
      powder coated wheels and seat
      Glenn Pettit Reproduction dash
    • T-Mo
      By T-Mo-(Moderator)
      1961 701s
