jbarnett
1975 C-120 Automatic
jbarnett
I have a 1975 Wheel Horse C-120 Automatic. For some reason (doesn't happen all the time...) it will suddenly start slowing down gradually making a slight muffled sound while running at full throttle and eventually stall. After it does that I can usually start it right up. Sometimes it continues to do that and other days it never does it. Any thoughts as to what might be wrong? I installed a new fuel pump and new battery last fall. I put a new coil on it a couple years ago. I'm fairly confident it's not an electrical issue. Could it be that my points, alternator, or the regulator/rectifier is bad?
I've heard before that sometimes the values stick on Kohler K301 when they are warm and a little Marvel's Mystery Oil might help prevent this if a little is added to the gas. I haven't tried that.
It seems to lose power all of a sudden when it's running at full throttle. It seems (could be my imagination..) but if I only run it at medium throttle it never starts the gradual slowing down, then stalling cycle.
Any thoughts?
Thanks,
Jeff
TT
:WRS:
The very first thing I would check is the gas cap vent.
Check for debris inside the gas tank too. (anything that could restrict flow)
wheeledhorseman
:WRS:
The second thing I'd check is the carburettor float bowl.
There could be some debris in there that's being drawn up into the jet on full throttle and which falls away again when the engine stops.
It's worth checking the jet itself as when something similar happened on my C-120 Auto the debris was actually sitting in the screwdriver slot of the jet itself.
Andy
jbarnett
Thanks for the suggestions. I'll definitely look into those things!
buckeye25
i would also check your points adjustment if they sliped a bit it wil run warm and sound muffled or tight kinda like it wants to make rpm and power but just cant do it but this only takes place at full rpm . the 10 hp k series in the 100 cubs were very bad at this during the last year of production. this might not be your problem but it sure sound familliar to me took four days of pulling my hair out and a few tears but finnaly figured it out.
horsenut
My dad bought one of these tractors in 75 and I still remember when it was delivered, runs like a champ to this day. These guys are right on, carb and points, if you've not replaced the points in awhile you may want to look into that as well...good luck and update this post...Real nice tractor for sure!
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
