Countdown To Christmas!
Similar Content
By Deer hunter
Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
By BrianStasC-101
Hello all. I am looking for suggestions on adapting the pto from my C series tractor to a harbor freight predator 420 13hp engine. I know the predator motors are a controversial topic however it is the route I have chosen for this particular machine. The intent was to mostly use it for plowing so no PTO required but it would be handy to have. Looking to hear from someone that has successfully done the swap that may offer any advice before I attempt to transfer it over. Just looking for any general pointers that will help me along the way to make it go as smoothly as possible.
By HumbleHans
Operator manual 810343R1
Wiring
34 pages 17.5MB
Wiring Colored
1 page 228KB
By t_furl43
1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well, it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4 -
By RJ Hamner
Will the plow I am using on my C121 and C160 work on a 876?
or is the plow frame different?
Thanks
Bob
