Stigian
Does anyone know the weights of....
Stigian
Hi Guy's I'm still trying to work out how to get a pallet shipped down from 'up North, and I thought it might be handy if I know how much the items are I need moving..
So does anyone know how much an Eaton hydro trans weighs?
Also I might be buying a Kohler twin from the same seller, any ideas on the engine weight?
Ta-muchly Chaps :thumbs:
tunahead72
Can't help you with the Eaton, sorry.
On the Kohler twins, it depends a little on which model. According to the owner's manuals, the KT17 weighs about 128 lbs. (58 kg), the Magnum M18/M20 about 130 lbs. (59 kg). I don't have anything on the Command CH18/CH20 models. These are all engines that were used on Wheel Horse tractors at some point.
Hope this helps.
Cheers!
sorekiwi
I'm heading out to the garage when I have finished my beer and my coffee, so I might be able to give you a definative answer later.
For now, I'll just say an Eaton 1100 is really effing heavy!!
sorekiwi
I'll let you do the metric conversion Ian.
The Eaton 1100 I have here weighs in at 165 lbs, complete with hubs, lift valve, lift cylinder, hoses etc. I am fairly sure that it still has oil in it too.
Hope this helps, and BTW my hernia hates you!!!
Stigian
Hope this helps.
Cheers!
Thanks Ed, that helps a lot.
Thanks Mike, yep they are rather heavy.
You must have some hefty scales kicking about the place to weight an Eaton 1100 :scared-eek::)
165lbs sounds lighter than than an Eaton feels lol, thanks for that Mike it certainly helps..
Can you pass on a message to your hernia that I'm sorry..
  • Similar Content
    • Bill D
      By Bill D
      I have to change some o-rings on my GT-1800.  What size o-rings do I need for the ORB-5 and ORB-6 fittings.  Also, does anyone make a ORB-5 to JIC-6 fitting?  Looking for both straight and 45 degree fittings.  Thanks.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • Salbreth1
      By Salbreth1
      Hello guys and thanks again for the welcome! So long story short, my wife calls me and says theirs a tractor on the trash. So like any normal human I hopped in my truck and drove up to find this 418-C and a set of aluminum ramps on the side of the road. Had to be fate.
      So me and my 6 year old sons new found love of tractor pulling has inspired this build. I’ve been researching everything about the model and currently have it stripped and prepping it for paint.
    • Salbreth1
      By Salbreth1
      Hello from Bennington Vermont. I picked up a 418-C on the curb and plan to build a stock class puller for my 6 year old. This one needs work as well as an engine but I’m excited for the restoration!
      sal
