MikesRJ
Restoration of a 1961 Wheel Horse Suburban 701
MikesRJ
Ok folks this is just the starting point for this restoration. I'll begin by saying what I've always said before concerning "restorations". A restoration is how YOU define it. I define mine as a complete tear down, replace, refurbish and/or refinish every single piece of this machine striving to achieve a 100% mechanically correct machine per the original Integrated Parts List. About the only thing non-original will be the method of painting. I will use primer, which Wheel Horse did not, but as added protection to the longevity of my "Restoration". Hope you all enjoy following along.
Here's where we start ...
VinsRJ
Mike, I look forward to your documented approach of this resto :thumbs: .... Will you be looking for a correct motor or going with the K181?
MikesRJ
Already have a "correct" K161 lined up, dual belt and deep belt cover and all. Also have the following parts either coming or already on hand:
Square Seat Pan
Hitch
Hitch Pin
Dash Plate
Decals
Muffler
Fenders
Gas Cap
Fuel Bowl
Front Tires
Clevis Pins
Hood Bracket
Knurled Hood Bolts
Still working on a positive ID (picture of originals) on the Throttle and Choke. Looking for a correct 2-prong starter switch, and other sundry items yet to be discovered.
TT
Best pic I have of a control knob:
That's on my 502, but it's the same as my 701.
Charlie claims there are early Jeep cables that are nearly identical, so you might want to check it out. :thumbs:
Toejam
Is that on/off switch and plate original to the 501? My 633 has that and I thought it was put on after the fact. Would it also be original to the 633?
I will be watching this rebuild very close because it looks so much like my 633. Good luck.
MikesRJ
In my research quest for this machine, I ran across an interesting fact. Take a look at the following picture:
How many people KNOW what the correct assembly order is for the items installed on the dashboard? Makes me wonder how many machines out there are installed incorrectly!
From left to right, they are ...
Choke, Throttle, Amp Guage, Starter Button, and 2-Prong Ignition Switch
(Reference pgs. 7, 9-11) http://www.mywheelhorse.com/graphics/file/...-701_6155-P.pdf
That had me befuddled. Thought this might be useful information to the masses.
MikesRJ
Speaking of 1961 Suburban 701 research, the best place to start is the original manuals for the subject at hand. To-wit I add the following documentation I am current pursuing.
SPECIFICATIONS
Product Brand: Wheel Horse
Model Number: 701
Serial #: 48317
Model Year: 1961
Chassis Type: Garden Tractor
Deck Swath: Deck Optional
Deck Discharge: Deck Optional
Engine Manufacturer: Kohler
Engine Model #: K161S-28622E
Engine Size: 7 hp
Engine Type: 4 Cycle
Engine Starter: Electric Starter-Generator
Transmission Manufacturer: Wheel Horse
Transmission Type: Gear
Transmission Speeds: 4 Speed
Transmission Model #: 5007
MANUALS
701 Owner's Manual (OM) and Integrated Parts List (IPL): http://www.mywheelhorse.com/graphics/file/...-701_6155-P.pdf
5007 Transmission Manual: http://www.mywheelhorse.com/graphics/file/...1958_-_1982.pdf
Engine Owner's Manual: http://www.mywheelhorse.com/graphics/file/...93_f_all_OM.pdf
Engine Owner's Manual #2: http://www.mywheelhorse.com/graphics/file/...181_1968-OM.pdf
Engine Service Manual: http://www.mywheelhorse.com/graphics/file/..._tp_2379_SM.pdf
Engine Service Manual #2: http://www.mywheelhorse.com/graphics/file/...1_1972-SM-2.pdf
Engine Integrated Parts List: http://www.mywheelhorse.com/graphics/file/...P_TP-1053-A.pdf
SERVICE BULLETINS
SB-19 5007 Transmissions: http://www.mywheelhorse.com/graphics/file/...Replacement.pdf
dclarke
Mike, i think there was some talk about this a while back. i don't remember exactly but i think they may have moved them around due to the dash breaking. i can't remember who posted it.
MalMac
Very interesting on the dash order. I see what your talking about looking at the parts diagram. Now I am confused, I have got a 701 that we bought new and the dash was set up the way the one is in the Photo. Choke,starter button,key, throttle. Came that way right out of the crate. I wonder which way it really is supposed to be. I do know as a being a machinist you get prints from engineers and what really happens when it's made can be totally different. Anyway thanks for pointing that out. It's got me thinking.
dclarke
Mike, Glenjeri explained it in one of his posts. i don't know how to post it here but do a search for "701 dash" then scroll down to "correct for a 701" he posted it there.
buckrancher
actually thats the prototype tractor the production tractors are choke,starter button,
amp gage,key switch, throttle
there was just a thread about this a couple of month's ago
production machines were changed do to breakage of the plastic dash from the stress of the choke,throttle cables next to each other the parts book was made from the prototype tractor
you should also notice the pto ingagement is done with a rod an nob from the hoodstrand to the pto pulley
and not the foot pedel that the production tractor used also on the front picture on the owners manual the tractor has a round seat and not the production square pan seat and no lift lever for a mower deck
check this out
http://www.wheelhorseforum.com/index.php?...687&hl=701+dash
Brian
MikesRJ
Spoke via PM with CharliesD250 and received the following information about the Throttle and Choke Cables. Both knobs are as TT described above. The knobs are convex crowned, black plastic knobs with White "THROTTLE" and CHOKE" lettering on them.
Charlie tells me that the "old" (1946-1971) Willey's Jeep throttle and choke cable knobs are identical to the Wheel Horse throttle and choke, with the exception of the base diameter. It appears the base diameter is somewhat different than the original, but inserting a "drilled out" 5/16" Stainless Steel washer will sufficiently make up for the diameter difference while maintaining the external appearance.
The throttle and choke cables should look like this (yes, I realize it's a crappy picture):
I have located and contacted a supplier who carries both, and asked the question; 'Is the throttle cable the 'twist-lock' style?". As soon as I have an answer in the affirmative I will place my order for a set. I'll also post details here when I get a solid answer or find the right ones, whichever comes first.
MikesRJ
Something else I found while researching 701 information is a post made by Terry (TT) in December of 2010. TT's post sums up the one-of-a-kind nature of the 701, and how the 701 is a stepping stone in this generation of round hoods. The post also contains some insightful details about the machine as well. The original thread can be viewed here: http://www.wheelhorseforum.com/index.php?...=0entry189885
Terry's Quote "
The 1961 701 was yet another milestone "small" tractor for the Pond's. Their first front-engined model designed for suburban homeowners, it strayed far away from the converted two-wheeled walk-behind based tractors built up until that point.
Although these round hood tractors look "the same" to many people, every year they were produced (1961 to 1964) showed improvements and refinements over the previous year(s) and gave each group their own "personality" or traits to enable them to be identified individually.
The 701 was the guinea pig of sorts and had a lot of "one-off" or unique pieces (or lack of) that were not used on any of the following models.
The most obvious would be the solid-front hood, the dual starter/generator belt system, and the lack of a parking brake and left side cover.
Some other unique (different) things:
The rear fenders had sharper rear corners and were mounted to a low tapered-side tool box and had diagonal support braces.
The steering wheel had three exposed steel spokes and was the same part used from late 1956/early 1957.
The 701 had a starter relay (solenoid) activated by a push button mounted in a plastic dash panel. Ignition power was controlled by a split key switch - also mounted in the dash panel.
Throttle and choke controls had small convex-faced knobs and the amp gauge had a black bezel.
All 701's produced had a single bend near the bottom of the shifter, since the HY-2 had not been introduced yet. It wasn't until part way in to '62 that the second bend showed up, which allowed the shifter to clear the pump unit.
There are variations in the steering components, including the lower support, lower shaft, tie rods, front axle, etc. that changed over the four year "run" of these tractors.
Too late to say this, but "long story short"..........
The 702 was - for the most part - the improved version of the 701. The 753 was the improved version of the 702, and the 1964 854 was the last and final tractor of this generation and was the improved version of the 753.
I could keep on typing about these, but it's probably easier (on me :wh: ) for you to ask specific questions though. :thumbs:
rydogg
Mike, that is the same throttle cable I ordered it is not a twist lock I was thinking of pinching some of the cable tube so it will not move on its own. I believe I have the original choke cable I got it with a 653 that I purchased from the same person that sold me the 701, I put it in the 653 since the original had a broken knob but now I guess I will be pulling it out for the 701 or ordering a Jeep choke cable also.
OOPS I just noticed TT posted a picture of the choke so I guess I didn't need to post my blurry picture his is easier to see.
sorry about the poor picture I broke the screen on my digital camera so I can't see what the picture looks like until I load it on my computer and this is the best out of 6 pictures
sscotsman
Is the 701 considered a "Surburban model"?
and should it be referred to as a "Suburban 701"?
I dont believe it should be considered a "Surburban", but im no expert! :thumbs:
I thought the only "suburban models" were the 1960 Suburban 400,
and the 1960 Suburban 550.
They are listed that way in this model list:
http://www.wheelhorseforum.com/index.php?showtopic=17174
So is that correct?
thanks,
Scot
DMK855
Looking forward to yet another great resto Mike!! :thumbs:
MikesRJ
You guys will appreciate this, and please keep in mind I am not bashing the seller, eBay, or the Post Office.
I ordered a set of the Jeep CJ2 Throttle and Choke cables for the 701 project. They were scheduled to arrive yesterday and something strange showed up in the priority mail tracking information. As of 4pm yesterday (Thursday) afternoon the info said "Out for delivery" as of 9:30 AM.
The package didn't arrive until today (Friday), and the envelope was shredded, open, and empty of any contents.
Along with it is a letter from the Philadelphia mail center stating they received it empty, and if I wanted to, I could refuse delivery by returning it to the carrier or to the post office. Well duh, you deliver an empty envelope, what the hell do you think I want to do, Keep It!?!?!?
So now I have to call the seller, file a claim with both PayPal and eBay, and wait an additional 2 weeks to get the cable, by the time all this crap is sorted out. Now I've bought a lot of things off eBay, and this is the first time this has happened to me, but how aggravating is that?
Indy w h
Well I guess you can go ahead and restore the tractor while you wait for the cables!!!!
What are you waiting for ????? Get on it !!!
Indy
MikesRJ
This weekend I plan to begin the diss-assembly of the machine. The first order of business is to get the transmission split, repaired and restored. followed by the frame, front end, and rims/tires.
MikesRJ
Finally received the two sets of (Jeep and Toro Throttle and Choke) cables I ordered. I find that the Jeep cables, and in particular the throttle cable, is NOT a twist-lock version unfortunately. Also the base of the Jeep cables is also not correct either. The knobs on the other hand are correct as far as I can tell, and the bases of the Toro cables appear to be the correct style. I considered transferring the Jeep cables into the Toro bases, unfortunately the cable shafts are too long for the Toro bases and stick out quite a ways when bottomed into the bases.
What I have done is taken the knobs off the Jeep cables and swapped them over to the Toro cables. This way the knobs are correct in appearance, and the cable assemblies are correct in appearance as well.
As you can see in the pictures below, the dashboard (purchased from one of our RS Vendors) is not the correct color. The correct color is white plastic, and this will require the dash to be colored white using VHT Vinyl Dye.
The Amp Gage is original, and the bezel will need to be repainted black. The started button is original and will need to be re-polished.The key switch should be a split key version, but I've yet to locate one for a reasonable price (I don't consider $40 and up reasonable for a $10-15 switch).
Any thoughts, comments or interjections?
Thus far the following parts have been aqcuired:
Square Seat Pan - check
Kohler K-161 w/Double Pulley cover - check
Hitch - check
Hitch Pin - check
Dash Plate - check
Decals - check
Muffler - Check
Fenders - check
Gas Cap - check
Fuel Bowl - check
Front Tires - check
Clevis Pins - check
Hood Bracket - check
Knurled Hood Bolts - check
Gerry w
I split the speedo on the VW and repainted the inside with model paint. What are you going to do Mike?
MikesRJ
Time will tell Gerry ... :thumbs:
That needle is beginning to get to me though.
puddlejumper
Mike, I think you will regret it if you try to take the bezel off. They are hard to recrimp due to streching when removed and its hard to find another without the stewart warner logo on the face. If you find some I could use one :thumbs:
Also Glen told me I think off white is correct for plastic dash and he also has white ones if youn prefer I ordered the off white specificaly
buckrancher
Mike
FYI I have two original dashs and I believe there both off white
Brian
  • Similar Content
    • Brad Schroder
      By Brad Schroder
      Looking for 701 (k161) parts. Starter/generator, right side belt cover, left side belt cover, air cleaner housing. Thanks
    • oliver2-44
      By oliver2-44
      This one was on Marketplace for quite a while with a hefty price tag.  I ask if he was flexible on price, Nope.  After a quite a while longer same question before I made the drive.  Come on up, maybe we can make a deal.  The rest is history, I didn't steal it, but I'm happy with the deal!
      Ya I know you want pictures, but there a little more interesting back story.  His granddad's business was Nicholson Machine and Equipment and he was a Wheelhorse Dealer in the 50's and 60's in Paris....., Tx  that is!  He sent me this picture of the glass window from the door to the business that he has framed.
      He also wrote me a short note about his Granddad's business.  So after his he passed, his dad gave the tractor to him. he's had it for quite a few years and said it's always been garage kept.
      So if a Dealer owned this for his own use and never sold it, and then it passed to his Son, and then Grandson, that would technically make me the 1st buyer,
        Ok so on to some tractor photo's
      beautiful double pulley belt guard front and center.  It starts with a spray of gas in the carb, but doesn't stay running.
      All there, nice and original, you can see a weld repair on the front of the belt guard,
      Here's the serial number @gwest_ca
      The plastic dash is intact and not cracked!
      My 1st old style split key.
      it still has the orignal Silverton Ags. They hold air, but their so hard they probable don't need any.  I wonder if their hard because they might still have calcium chloride in them???
      The hitch pin isn't frozen and the lift cable even works.
      Interesting decal plastered across the front of the hood.
      aluminum gas tank is fairly clean.
      Hood bottom tab has been repaired.
      topless view of the engine, needs a bath. The front tires are original and hold air, but have some splits across the thread.
      Homemade choke and throttle cable bracket.  The base of the engine has wet oil, so i suspect it needs some gaskets.
      Both axle seals are dry, but the input shaft and brake shaft seals leak.
      I've learned if the top of the transmission is filthy oily, it probable means theirs water in the transmission that has floated the oil out.  This one is clean so hopefully that's a good sign.
      Started some maintenance and a beautiful sight, not a drop of water, just black oil.  It shifts through the gears nicely so it will be interesting to see how it runs/drives.
      I'll gradually go all through it with my checklist.  701 Minor Overhaul Checklist.ods
      Then have to decide if I rub it down with linseed oil like it is, or buff with some steel wool or wet sand to bring a little more red out, then oil.
      How would ya'll put your finishing touches on it?
      I'll update this thread as I do maintenance on it and get it running.
    • wh315-8
      By wh315-8
      So just picked up a 701, obviously the engine isn't right. I have a 7hp Kohler to put on and will put B&S on my Speedex. Anyone ever seen a post come out on the right from the rock shaft? It rotates with the lift handle and has no holes in it. It was done up well, almost looking factory.
    • chompinthebit
      By chompinthebit
      Hi all,
      i bought this 1961 701 in fall of 2018 and restored it. I completed it in fall of 2019 and I wanted to show some pictures of before during and after I got it done. I did my research and tried to make this tractor as close to original as possible. The few exceptions are tires, wiring and the steering support. Not a perfect tractor but sure is nice enough for me.
      all stainless hardware
      Rustolium stops rust Primer
      Rustolium Regal Red enamel paint
      powder coated wheels and seat
      Glenn Pettit Reproduction dash
    • T-Mo
      By T-Mo-(Moderator)
      1961 701s
