Stigian 1,234 #1 Posted March 28, 2008 Its been a quiet week on the WH front, not much has got done other than fitting new wheels and a roller to the Raiders cutting deck. Most of the week has been spent getting Betsie (the Pick-up) ready for service You know the sort of thing, fixing the door locks, a bit of welding here and there, fix the radio, make up a winch mounting point, etc Anyway, yesterday Garry and i thought it was about time we got a 'orse in the back to find out how easy it was Two things we learn't yesterday 1 Always make sure your pick-up is wide enough for your mower, we had to take the duels off the back while the WH was half way up the ramp 2 Make sure your winch has a reverse on it, the hand crank one we used didnt, so new longer ramps had to be found so i could drive the 'orse out the back again Do you think the Raider rims and rubber suit it? Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,666 #2 Posted March 28, 2008 Ian, I loved the clean lines and the look of that truck's cab. Be careful with those wooden ramps, though, that they don't kick out from under you when you use them. Maybe buy one of those ramp kits that bolt to 2 x 8's. I used a set for a couple of years - worked great. They now reside as anchor points into my shed. Hmm, I do like the looks of the Raider rims and tires for your truck. :thumbs: Share this post Link to post Share on other sites
Nick 13 #3 Posted March 28, 2008 Ian, Your Ford has a longer bed than I had thought. Doesnt look like it sits very high, maybe you could build a folding ramp gate for the back. If the tractor gets hauled often it might come in handy. This company makes a ramp that fold up at the back. Im sure you could build a ramp setup like it. Discount ramps Nick in Ohio Share this post Link to post Share on other sites
perry 82 #4 Posted March 28, 2008 i agree with the others..GET RID OF THOSE BOARDS. i have seen too many accidents with using plain boards. i built a set of wood ramps for my pickup, but i either push'em up or stick the tractor in 1st gear and let it go up the ramps by itself. a tractor is heavyier than you think when its on top of you,,,,i have seen it happen. i like that little pick-up . Share this post Link to post Share on other sites
Rollerman 290 #5 Posted March 28, 2008 Ian is your truck a rear or front drive? The cab does remind me of a Merkur I used to have. I think TT said that they resemble them too? Oh and the ags look great...but may give you fits driveing in the rain. :thumbs: Share this post Link to post Share on other sites
Stigian 1,234 #6 Posted March 30, 2008 Cheers for all the concerns about the ramps, you are a caring bunch The boards in the photo's were only used for winching the 'orse into the back of the wagon, and yes they were not really ideal for the job The new ramps that were needed to get the 'orse back off the truck are a lot thicker, a lot longer, and are also the same size All they need is a thick metal plate on the ends to hook over a big lip in the pick-up bed. Most of the mowers will be pushed up into the pick-up bed, but id better get an electric winch for those that dont like turning wheels Ian is your truck a rear or front drive? It drives from the right end Stephen :D Share this post Link to post Share on other sites
