HorseFixer
WOW! Looks Good Denny...... I can tell you dont goof off like me and watch football on Saturdays! :hilarious: Ill hafta ck my casting number and see what it says.
Be glad to get that Clunker snow chucker done So's I can get back on a real tractor. :eusa-whistle: If ya need a nice place to park it when yer done lord knows yer welcome to
bring it over. :ychain:
dclarke
This week I got the tranny put back together with new bearings and seals and replaced a few gears with better ones. I also took the motor generator apart, cleaned it up and reassembled it. The hood is too big to fit in my blast cabinet and I thought the guy that blasted my frame might warp it so I bought this little blaster from Harbor Freight and did it myself. I was surprised at how well it worked. The engine block is the only thing I have left to clean, now I'm just waiting for the painter to call.
AMC RULES
OH sooooooo clean...everything looks like it's surgical steel Denny.
Seems Dr. Denny is in. :thumbs:
rmaynard
Looking good Denny. What type of media did you use in the blaster?
dclarke
Bob, I used glass beads. That's what I use in my cabinet.
rmaynard
Thanks Denny. Getting ready to do some blasting and can't risk warping the hood. I was looking at walnut shell media. Guess I need to do some more research.
dclarke
Bob, I've never used anything but glass, walnut shells may work better... I stripped the paint off the hood with decal/paint stripper before I blasted it and there really wasn't much rust on it so it didn't take much.
MalMac
Boy Denny you make get all kinds of ants in the pants wanting to get going on my 701, just the wrong time of year if you know what I mean.
shorts
corn cob media works good and is less costly than walnut shells, especially if you are blasting sheetmetal outside. I also like the idea of using a chemical stripper first to remove the paint before blasting
HorseFixer
Looks Fantastic Denny. I use Aluminum Oxide in my cabinet I got from Harbor Freight I can usually get two uses out of it. I havent tried a Pot Blaster yet but A I think Aluminum Oxide may be a bit pricey for that. :) Makes me wanna get on mine too! :thumbs:
~Duke
dclarke
~Duke
Duke, I'll look for something cheaper next time I use that blaster. Too much of it goes away to spend a lot of money on media.
Kelly
I have a HF pressure blaster a lot like that, mine is 15 years old, I use Flint shot in it, it is a sand made for blasting, it is coarse but takes rust off good, I lay a 25'x25' tarp in the drive way and blast in the middle,(don't blast the tarp it will get a hole RIGHT NOW) when done I pick a corner up and run the sand to the middle one corner at a time, then use a kids sand shovel to scoop it up and dump it on a old window screen setting on top of a 5 gal. pail, so I can reuse most of it, after it has been used a few times I set it aside for fine work as it will get worn out, in my blast cabinet I use glass bead.
buckrancher
I just use whatever tsc sells
CasualObserver
I noticed an extra set of numbers cast into some of my unidrive housings. The part numbers for the housings are the same, 3900 and 3901. Anybody know what the other numbers mean?
Denny, those are casting date codes. One half of your case was cast on April 20, 1961 (D20%1) and the other May 18, 1961 (E18%1). Of course at assembly, those parts are all mixed and laying on pallets, so they don't have matching dates.
Ken B
701 looks awesome Denny! I'd love to see it in person some day.
dclarke
Jason, Thanks for the info...... I have another question, The tranny that came with the tractor has a 1/4" npt fill hole and no date codes (it looked to be original to the tractor) and the one with the date codes, built in 1961 has a 3/8" npt fill hole. Do you or anyone else know which one is correct for this tractor? Just curious.
CasualObserver
I don't know. Maybe someone else has insight to that one. Could be that they discontinued the date codes at some point. Really wish there were engineering records we could reference for trivial stuff like that.
Sent from my Galaxy S iii with Tapatalk 2
Terry M
Looks good Denny!! can't wait to see it done for power pioneer days next year!! :teasing-poke: And those rims look nice too :bow-blue: . To me powder coating is well worth the money when it comes to painting rims. :handgestures-thumbupright:
dclarke
I got these decals in the mail from Terry today, he did a lot of work on them to get them "just right". They'll really add a nice finishing touch to my tractor. I shot a closeup of the spec/sn decal and the motor generator decal to show how nice they are..... Thanks Terry!!
rmaynard
Looks good. I'm still waiting on decals from Terry for mine. Nice to see he can do those Delco labels.
Fun Engineer
Very nice Denny. Terry really does nice work.
MalMac
Denny are you going to try and put the tag decals right over the original tags or just do away with the tags all together and just use the decals.
dclarke
Tim, I have a new tag for the generator that I'll put the decal on and I have bought a small sheet of aluminum to make a new spec/sn tag.
dclarke
I have a question about the piston rings in this k161 I'd like to get some opinions on.... When I built this engine a couple of years ago I had it bored .010 and installed new rings at that time. Now I have completely disassembled the engine so I can clean the block and get it ready to paint. I'm going to blast it to take it down to bare metal. The engine probably don't have 8 or 10 hours on it since I rebuilt it, My question is.... should I deglaze the cylinder and install new rings when I put it back together or can I put the rings back in it that are on the piston now?
rmaynard
I think that 8 hours is essentially still breaking in. I would do nothing.
Sent from my MB520 using Tapatalk 2
  • Similar Content
    • Brad Schroder
      By Brad Schroder
      Looking for 701 (k161) parts. Starter/generator, right side belt cover, left side belt cover, air cleaner housing. Thanks
    • oliver2-44
      By oliver2-44
      This one was on Marketplace for quite a while with a hefty price tag.  I ask if he was flexible on price, Nope.  After a quite a while longer same question before I made the drive.  Come on up, maybe we can make a deal.  The rest is history, I didn't steal it, but I'm happy with the deal!
      Ya I know you want pictures, but there a little more interesting back story.  His granddad's business was Nicholson Machine and Equipment and he was a Wheelhorse Dealer in the 50's and 60's in Paris....., Tx  that is!  He sent me this picture of the glass window from the door to the business that he has framed.
      He also wrote me a short note about his Granddad's business.  So after his he passed, his dad gave the tractor to him. he's had it for quite a few years and said it's always been garage kept.
      So if a Dealer owned this for his own use and never sold it, and then it passed to his Son, and then Grandson, that would technically make me the 1st buyer,
        Ok so on to some tractor photo's
      beautiful double pulley belt guard front and center.  It starts with a spray of gas in the carb, but doesn't stay running.
      All there, nice and original, you can see a weld repair on the front of the belt guard,
      Here's the serial number @gwest_ca
      The plastic dash is intact and not cracked!
      My 1st old style split key.
      it still has the orignal Silverton Ags. They hold air, but their so hard they probable don't need any.  I wonder if their hard because they might still have calcium chloride in them???
      The hitch pin isn't frozen and the lift cable even works.
      Interesting decal plastered across the front of the hood.
      aluminum gas tank is fairly clean.
      Hood bottom tab has been repaired.
      topless view of the engine, needs a bath. The front tires are original and hold air, but have some splits across the thread.
      Homemade choke and throttle cable bracket.  The base of the engine has wet oil, so i suspect it needs some gaskets.
      Both axle seals are dry, but the input shaft and brake shaft seals leak.
      I've learned if the top of the transmission is filthy oily, it probable means theirs water in the transmission that has floated the oil out.  This one is clean so hopefully that's a good sign.
      Started some maintenance and a beautiful sight, not a drop of water, just black oil.  It shifts through the gears nicely so it will be interesting to see how it runs/drives.
      I'll gradually go all through it with my checklist.  701 Minor Overhaul Checklist.ods
      Then have to decide if I rub it down with linseed oil like it is, or buff with some steel wool or wet sand to bring a little more red out, then oil.
      How would ya'll put your finishing touches on it?
      I'll update this thread as I do maintenance on it and get it running.
    • wh315-8
      By wh315-8
      So just picked up a 701, obviously the engine isn't right. I have a 7hp Kohler to put on and will put B&S on my Speedex. Anyone ever seen a post come out on the right from the rock shaft? It rotates with the lift handle and has no holes in it. It was done up well, almost looking factory.
    • chompinthebit
      By chompinthebit
      Hi all,
      i bought this 1961 701 in fall of 2018 and restored it. I completed it in fall of 2019 and I wanted to show some pictures of before during and after I got it done. I did my research and tried to make this tractor as close to original as possible. The few exceptions are tires, wiring and the steering support. Not a perfect tractor but sure is nice enough for me.
      all stainless hardware
      Rustolium stops rust Primer
      Rustolium Regal Red enamel paint
      powder coated wheels and seat
      Glenn Pettit Reproduction dash
    • T-Mo
      By T-Mo-(Moderator)
      1961 701s
