MalMac
Well Denny you did it! The long labor of love with some aggravation thrown in is over. Now it's time to stop and take a breath and relax till the next one. It turned out great. Helps motivate me on mine. Congrats on a fantastic restore from the ground up.
wingrider
That sure is a great looking 701 Denny. How long did it take to get it finished? Did you have trouble finding parts?
I know you will have a great time showing it off at the shows coming up.
Once again GREAT JOB!!!
Wingrider
Edited by wingrider
dclarke
Wingrider
I've been working on it off and on since I got it in Feb. of '09.  Seems every time I had a little money to spend on it I'd find another Horse that I had to have. Some of the parts were a little hard to find but to me the search is part of the fun. Along the way I had an awful lot of help from several members here.
AMC RULES
:handgestures-salute:  I can't wait for the next one Denny.   :text-bravo:
dclarke
Today I got the lights installed and the last thing to do was install the spec. plate for the engine. My old one was in sad shape so I bought a decal from Terry and had a new plate cut from aluminum. Turned out pretty good.  Nice job, Terry!  Some day I'll paint the letters on the front of the hood but for now, I'm done.
One last shot, this one's for you, Bob.
Edited by dclarke
  • Like 4
Fun Engineer
I saw this beauty two weeks ago and guys, she's a work of art. Great job Denny.
clemedc
WOW looks awesome finished Denny :bow-blue:
Ken B
Wow that looks fantastic Denny! Love the Bob Maynard shot!
UncleJerm76
On 2/9/2010 at 3:55 PM, Lane Ranger said:
This outfit sells a coating that is just as good if not better than POR-15 and I have used it. I would suggets buying the pint cans.
http://www.kbs-coatings.com/
I used the KBS process when I built a 14ft trailer because it doesnt get parked under any kind of protection. That was years ago, the trailer has always sat out in the open hot FL sun, nasty humid rain and is even nearby an oak tree that appears to take pleasure in piling leaves on the trailer between uses. Not a single evidence of any rust yet! I now swear by KBS as far as rust performance. Proper application was a bit of a time consuming pain though. It was a three-step process + your own paint. 1) Clean with a product, 2) Treat with another product, and 3) lastly apply their rust coating product. You then have a limited window to paint over top of it with your own paint. It is not recommended to paint over KBS after it has fully cured due to issues with paint adhering to the cured KBS surface.
All that being said, The trailer surfaces certainly don't get the harsh blasting that the underside of a mower de3ck gets. I don't know of ANY product that can stand up to the harsh sand blasting environment of the underside of a mower deck! If this is going to be a work tractor, time tested practices include cleaning and painting the underside of the deck each season to keep it healthy. It would be a waste of time and money IMO to do anything other than just using good paint on a mower belly. If its going to be a show tractor - then Id recommend just using better paint, but I doubt the 701 in this build will EVER get left out in the elements long enough for rust to ever settle under a good paint.
UncleJerm76
On 3/18/2010 at 8:10 PM, dclarke said:
now i can't seem to keep the mower blades from turning when the idler pulley is disengaged. anybody know what i did wrong this time?
I know this is an old thread, but I read about this just the other day in on of the 701 manuals or services bulletins for this mower deck. Wheel Horse called it "Windmilling" when the blades rotated on their own while disengaged. It said to prevent windmilling make sure the deck is in the raised position. ...at least that was the solution back in 1961   ...food for thought.
Being a 701 owner myself I REALLY enjoyed reading this build. Thank you very much for sharing it with us!
  • Similar Content
    • Brad Schroder
      By Brad Schroder
      Looking for 701 (k161) parts. Starter/generator, right side belt cover, left side belt cover, air cleaner housing. Thanks
    • oliver2-44
      By oliver2-44
      This one was on Marketplace for quite a while with a hefty price tag.  I ask if he was flexible on price, Nope.  After a quite a while longer same question before I made the drive.  Come on up, maybe we can make a deal.  The rest is history, I didn't steal it, but I'm happy with the deal!
      Ya I know you want pictures, but there a little more interesting back story.  His granddad's business was Nicholson Machine and Equipment and he was a Wheelhorse Dealer in the 50's and 60's in Paris....., Tx  that is!  He sent me this picture of the glass window from the door to the business that he has framed.
      He also wrote me a short note about his Granddad's business.  So after his he passed, his dad gave the tractor to him. he's had it for quite a few years and said it's always been garage kept.
      So if a Dealer owned this for his own use and never sold it, and then it passed to his Son, and then Grandson, that would technically make me the 1st buyer,
        Ok so on to some tractor photo's
      beautiful double pulley belt guard front and center.  It starts with a spray of gas in the carb, but doesn't stay running.
      All there, nice and original, you can see a weld repair on the front of the belt guard,
      Here's the serial number @gwest_ca
      The plastic dash is intact and not cracked!
      My 1st old style split key.
      it still has the orignal Silverton Ags. They hold air, but their so hard they probable don't need any.  I wonder if their hard because they might still have calcium chloride in them???
      The hitch pin isn't frozen and the lift cable even works.
      Interesting decal plastered across the front of the hood.
      aluminum gas tank is fairly clean.
      Hood bottom tab has been repaired.
      topless view of the engine, needs a bath. The front tires are original and hold air, but have some splits across the thread.
      Homemade choke and throttle cable bracket.  The base of the engine has wet oil, so i suspect it needs some gaskets.
      Both axle seals are dry, but the input shaft and brake shaft seals leak.
      I've learned if the top of the transmission is filthy oily, it probable means theirs water in the transmission that has floated the oil out.  This one is clean so hopefully that's a good sign.
      Started some maintenance and a beautiful sight, not a drop of water, just black oil.  It shifts through the gears nicely so it will be interesting to see how it runs/drives.
      I'll gradually go all through it with my checklist.  701 Minor Overhaul Checklist.ods
      Then have to decide if I rub it down with linseed oil like it is, or buff with some steel wool or wet sand to bring a little more red out, then oil.
      How would ya'll put your finishing touches on it?
      I'll update this thread as I do maintenance on it and get it running.
    • wh315-8
      By wh315-8
      So just picked up a 701, obviously the engine isn't right. I have a 7hp Kohler to put on and will put B&S on my Speedex. Anyone ever seen a post come out on the right from the rock shaft? It rotates with the lift handle and has no holes in it. It was done up well, almost looking factory.
    • chompinthebit
      By chompinthebit
      Hi all,
      i bought this 1961 701 in fall of 2018 and restored it. I completed it in fall of 2019 and I wanted to show some pictures of before during and after I got it done. I did my research and tried to make this tractor as close to original as possible. The few exceptions are tires, wiring and the steering support. Not a perfect tractor but sure is nice enough for me.
      all stainless hardware
      Rustolium stops rust Primer
      Rustolium Regal Red enamel paint
      powder coated wheels and seat
      Glenn Pettit Reproduction dash
    • T-Mo
      By T-Mo-(Moderator)
      1961 701s
