ohiofarmer
Just when you wanted to hate the internet sellers
ohiofarmer
   I have a Maxium pellet furnace and the fan that provides forced air combustion quit running.  I went to the open internet and asked why the fan is not running because the control wires had a three wire feed connector and the seller advised me on it . a power lead, a neutral , and a chassis ground . He described the second connection as a external connection to the capacitor.  Maxium only sells complete units for over seven hundred. As fast as I could ask, he supplied me with answers about things including that i could replace the capacitor at grainger or someplace if that proves out . i told him that I would first clean the connector with contact cleaner and he said it was a great idea. Even though he might not make a penny on this problem , he gave advice that actually led away from his sales opportunity.
   Twin Waters Energy [10991] on Ebay is his location.  So if you have a hot water boiler that is wood fired or pellet fired , this may be a company to consider.
    In true farmer repair fashion, I rigged a shop vac to supply combustion air through the combustion fan.  I can ceate a gap in the air feed hose to adjust the airflow. Red Green would be proud.
Edited by ohiofarmer
  • Excellent 1
ri702bill
I had a similar good experience with an Ariens dealer years ago. I was gifted a running mid 1970's SnoThro - used it for one larrge snowstorm and noticed the second stage imperrer had broken the 2 spring pins and would not force the snow up the chute. I inquired at a local Ariens Sales / Repair shop if they could fix it - they were backlogged heavily with repairs & declined to do it - BUT - walked me thru the disassembly & repair. He advised changing the sealed ball bearing too - as it requires removing the impeller shaft too. I went htere to buy the bearing & he threw the 2 spring pins for free. And yes, the bearing was on its way out.... Not my closest Ariens Dealer, but the better one.
  • Excellent 1
